TR2/3/3A Mystery 57 TR3 part
gsalt57tr3
Oops.
OK, admit it, you've forgoten to label a part in your restoration. I need your help in identifying a pair of parts.
I remember stripping paint from these parts, but I can't remember where they came from. Anyone want to help me out?
Please?
The small bright circle is a quarter (for size reference, not a reward).
/ubbthreads/images/graemlins/confused.gif
Rear fender stays?
Or dash support stays?
They go on when you put the rear fenders on. The go at the last hole to the back. If you look inside the trunk where the screw holes for the fender go, it gets attached on the opposite side of the back holes. It's actually just the last weld nut for the rear fender. The reason for the extension is to hold some clamping pressure for the last few inches of fender.
Mickey (again) and martx
Thank you very much!
I've seen these in catalogs before, however, don't remember ever pulling one off of my 1959 TR3A. I'm pretty sure the fenders had never been pulled before my removing them. Would it be possible for the 1959 not to have these? Or has my memory (once again) failed me?
Yep, rear wing braces, Martex is quite correct. Just bought a pair for my '60-3A. Yours look slightly bent, at least in the picture anyway. The long body should be straight.
Regards, Tinkerman
mgedit TR2/3/3A Mystery Part 56 TR3 Triumph 6
mountainman TR2/3/3A Tr3 Mystery Part Triumph 3
martx-5 TR2/3/3A Now I have a mystery TR3 part... Triumph 3
J TR2/3/3A TR3 gas tank mystery Triumph 5
K TR2/3/3A TR3 SU Carb Mystery? Triumph 16
TR3TR6 TR2/3/3A TR3 mystery bolts Triumph 4
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
Moseso TR2/3/3A TR3 Cooling System Mystery Triumph 4
mcguijo TR2/3/3A exciting suspension mystery for tr3 Triumph 5
J TR2/3/3A TR3 No spark - Ignition mystery Triumph 27
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
