Hey Guest! BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Last steps of flood restoration. Interior is going back in. I need to refinish the steering wheel. Anyone ever done this? Process and product recommendations?
Can we have a look at it?
We will then be able to make better recommendations.
If the wheel is wood and shot, sand and plastic coat then cover with a leather wheel skin.
Kirk, It sounds like the clear coat has gone bad on the aluminum and needs to be stripped. No big deal, just buy some stripper from your local hardware store and do the wood at the same time. After all has been cleaner with denatured alcohol tape the wood to keep wax off, polish the aluminum, clean again with the alcohol now you can spray it all with clear poly, not lacquer. Give it two or three coats, sand with 2000 grit wet and dry sandpaper with soap and water, spray 3 more coats and do it one more time and it will look like new.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
