MGB MGB with Leaky brakes?
Norton47
The B seems to have a spongy brake pedal. Pump it and it works fine, but let off and it drops lower but you can pump it up.
No sign of leakage.
Decided to flush the system and I used a syringe to empty the master cylinder reservoir and then topped off with clean fluid. But every brake has streams of bubbles when when using a vacuum pump to suck the fluid through the brake actuator.
I have put grease around the bleeder screws so the air is coming from in the system.
Is this a firm indication of a bad Master cylinder with an internal leak?
As I stated I don't see any fluid leaks.
Other ideas?
Thanks
You still get the spongy pedal? It pumps up solid still and then lets off?
Kit or R2 the master cylinder. Brakes
Just a quick sanity check. I have pulled the master cylinder.
I wanted to check that the rest of the lines and cylinders were air tight.
So I attached a vacuum pump to each line that was attached to the M.C. one at a time and pumped it down. Both pumped down and held a vacuum. I think this would verify that the lines, connections and seals in the wheel cylinders and calipers are all air tight?
Would everyone agree?
Thanks
R MGB 74 MGB Chrome Bumper New Harness MG 3
wkilleffer MGB MGB windshield replacement near me MG 7
T Wanted MGB Coil Over Front Suspension MG Classifieds 0
R MGB 74 MGB Chrome bumper Grounding (Polarity) Question MG 7
Carlbanan56 MGB MGB cylinder head MG 11
C MGB MGB steering rack MG 0
D MGB 1979 MGB for sale near me MG 3
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 10
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 1
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
