MGB MGB engine starting problems
Rick31
Andy ideas on why my MGB Roadster is not starting??
When you turn the key all you get is a clicking noise. Seems like some sort of electrical problem.
The battery is new and I have fitted a new ignition coil just in case that was the problem but no joy (aarghh!)
Would welcome any ideas at all
many thanks
Welcome to the Forum Rick31!
If you've got a "rat-tat-tat-" type of clicking it would be likely the starter motor is the problem. If it's just one "click" per turn of the key and nothing after, it may be the relay or the solenoid. If you have a second pair of hands, get yer cricket bat and THUMP the starter motor solidly (in NEUTRAL please!) as the other person energises the starter. If it spins up then, the starter motor is definitely the problem.
Sounds daft but it works.
Thanks for that. Just trying to source one now. Noticed on a forum that the part is a common part and should be quite cheap! Noticed in the engine that there are two of these black boxes. Should it be easy to determine which is the starter relay?
Thanks for your help
Rick
Wire colour will be the giveaway: Whichever one has the connection with the same colour as the starter and a white/red is the starter relay.
Thanks.
The sound is just one single click when I turn the key so possibly a relay problem?
Any idea of costs for this part normally so that I don't get ripped off by any dealers?
Not a clue what it'd be in UK. Something below $50US. It may be MUCH less there.
Another question if anyone can help....
Attached to the fixing bracket of my ignition coil is a small oval box with a wire coming from it which in my MGB (1980 model) just hangs loose and is not attached to anything.
Wondered if anyone know what it is and if it is supposed to be connected to anything?
Could this be a condensor for RF suppression? I don't recall that from your description.... mebbe post a photo?
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
boxofparts MGB MGB Engine removal MG 5
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
S MGA 5 bolt MGB engine conversion into a MGA MG 2
T MGB Engine Rebuild on 74 MGB MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
vping MGB MGB Engine Block Casting Numbers MG 2
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB 80 MGB engine earth strap MG 11
Monark192 MGA MGB engine in an MGA MG 8
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
D MGB New engine for the MGB MG 4
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
J MGA MGB engine for MGA MG 15
V MGB MGB engine removal.... MG 1
L MGB MGB Engine Problems Again ? MG 10
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
