MGB MGB Engine Block Casting Numbers
vping
Bronze
Does anyone have any knowledge of what the Engine casting Number means or can they point me in the direction of a chart or link? I have several blocks without the Engine ID plate so I want to see if I can round about identify then by their casting number.
Look for the casting clock...tells day, month, & year cast.
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
boxofparts MGB MGB Engine removal MG 5
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
S MGA 5 bolt MGB engine conversion into a MGA MG 2
T MGB Engine Rebuild on 74 MGB MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB 80 MGB engine earth strap MG 11
R MGB MGB engine starting problems MG 9
Monark192 MGA MGB engine in an MGA MG 8
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
D MGB New engine for the MGB MG 4
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
J MGA MGB engine for MGA MG 15
V MGB MGB engine removal.... MG 1
L MGB MGB Engine Problems Again ? MG 10
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
