MGB 80 MGB engine earth strap
Rick31
Trying to locate the engine earth strap on an 80 MGB to check its condition and fixings but not sure where to find it?
Looked in Haynes, but to a newcomer like myself that book is next to useless as it expects you to know were things are.
Any info would be great as I am beginning to learn my way around the engine slowly!
Should be one on the port side motor mount. Steel braided cable with lugs on each end, held in place by engine mounting bolts.
Hope that helps!
You should see it from on top, peering down at the mount. It's short, about 6" long and looped from chassis bolt to motor mount bolt.
Thanks will have a look. On an earlier look today around that area I did notice a rusted bolt fixing on the engine but no cable there. Wondering if the cable is missing and the possible cause of my non engine turn over? The car did fire up last weekend and I went for a drive of 30 miles or so. The next day no start. Would it be possible for the car to work without this cable?
It will look for a ground when you engage the starter. If it is missing a stout grounding strap it can track thru the throttle cable and make a right mess of things. I've seen many LBC's with FUSED cables and assorted other metal bits hot enough to start a fire. Best if you take the time to confirm it's in place or PUT one there as precaution. Results of NOT having it secure are kinda ugly.
Just had a thought: your car is "newer" so p'raps the grounding strap is at the starter motor mounting bolts. Starboard side, pro'lly easiest to see from under the car.
If you don't find it in all the above places, look back on the transmission.
If you don't find one add one now. Anywhere is good for an immidate fix.
On both my '79 and '80 MGBs, the engine earth strap was on the right hand side, at the rear of the engine block, bolted to the firewall. It takes the form of a flat, braided steel strap, about an inch or so wide.
There ya go! Thanks, Steve. I thought I recalled the "later" cars had it back there instead of the motor mount.
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
boxofparts MGB MGB Engine removal MG 5
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
S MGA 5 bolt MGB engine conversion into a MGA MG 2
T MGB Engine Rebuild on 74 MGB MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
vping MGB MGB Engine Block Casting Numbers MG 2
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB MGB engine starting problems MG 9
Monark192 MGA MGB engine in an MGA MG 8
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
D MGB New engine for the MGB MG 4
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
J MGA MGB engine for MGA MG 15
V MGB MGB engine removal.... MG 1
L MGB MGB Engine Problems Again ? MG 10
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
