MGA MGB engine in an MGA
Monark192
How well does it fit? How about the transmission? Any major surgery required that couldn't be undone? Is it a bad idea? Just wondering out loud......
It depends on which MGB engine you'r talking about. If you can find an early 3-main 1800 from a '62-'64 MGB, it will be a direct bolt-in. The block is essentially a bored out 1622 MGA unit. Later MGB engines also basically bolt in but there will be some slight modifications necessary.
The 3-main 1800 will also allow the use of your current tachometer, as it has a mechanical drive on the block just like the MGA engine does. Later MGBs have electronic tachs so you would need to change that out.
I have an early 1800 in my MGA. I have retained the MGA carburetors, air filters, intake and exhaust manifolds, generator, etc. Only the block and head are MGB and unless you really know what you're looking for you will never be able to tell the difference. I also have the stock MGA transmission in the car.
The MGB engine I'm building now has been in a MGA for like 20 years, it's already been rebuilt once when originally installed. Now I can't tell you much about the fit of the MGB engine in the MGA, other than it must not be that big of a deal, lots of folks have done and are doing this. The engine I'm rebuilding for the MGA is a 18GB 5 main with the MGA backing plate and a pre-1968 MGB flywheel, no tach on the back of the cam, so I'm assuming they have switch tachs.
The MGB engine I'm building now has been in a MGA for like 20 years, it's already been rebuilt once when originally installed. Now I can't tell you much about the fit of the MGB engine in the MGA (this engine was shipped to me from a shop in Florida), other than it must not be that big of a deal, lots of folks have done and are doing this. The engine I'm rebuilding for the MGA is a 18GB 5 main with the MGA backing plate and a pre-1968 MGB flywheel, no tach on the back of the cam, so I'm assuming they have switch tachs.
Hope this helps.
To use a 5-main MGB engine in the A you will need that special "conversion" pilot bushing since the input shaft from the trans is small on the 3-main engines but much bigger on the 5-main engines. The bushing is avail from VB or Moss (can't remember which)
Bill
I had to install one of the conversion pilot bushings in my B. The Moss part number is 330-570, and runs about $25.00.
Will the MGB trans fit as well? I have a complete running 1974.5 mgb engine and trans vs. nothing for the 'A.
MGA transmissions are pretty cheap and easy to find. It would be easier to fit this than the later, larger unit. It has a nice vintage "mechanical" feel to it also which the MGB unit will not have.
S MGA 5 bolt MGB engine conversion into a MGA MG 2
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
J MGA MGB engine for MGA MG 15
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
boxofparts MGB MGB Engine removal MG 5
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
T MGB Engine Rebuild on 74 MGB MG 4
vping MGB MGB Engine Block Casting Numbers MG 2
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB 80 MGB engine earth strap MG 11
R MGB MGB engine starting problems MG 9
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
D MGB New engine for the MGB MG 4
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
V MGB MGB engine removal.... MG 1
L MGB MGB Engine Problems Again ? MG 10
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
