Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
You would want the L32 engine that came in 1993-1995 Camaros and Firebirds. 160 reliable BHP. When matching a transmission for it bear in mind that the T5 came with different mounts on GM than Mustangs, where they also used them.
Good morning. My next question is about the T5 transmission. I am seeing a lot of different models out there and don't want to buy something that is geared wrong or has the wrong bellhousing. From my research it looks like the T5 gearing for a V8 or even a large V6 is totally different than what was used in a 3.4L. Should I be looking for a T5 from a 3.4L, 2.8L and possibly even a 2.5L to better match gearing?
Gear ratios are important! With the MGB's rear end, you want the highest (lowest number) 5th gear. Look for one with .68 in fifth. Also, you want the "World Class" T5, as it has the beefed-up input shaft bearings. They're hard to find, but out there.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
