MG Midget serial numbers
Gunner
Have my new 1967 Midget home.. cranked her up for the first time... runs great.. it has been sitting in a garage for six months. Now... the serial number is in the forward driver's door jam on the hinge a-frame, not under the hood. Serial # GBE 058759. Anyone familiar with this? Also, the engine has a six blade radiator fan, and holes in the head on the spark plug side that are pluged with large threaded bolt plugs. /ubbthreads/images/graemlins/driving.gif Any guesses would be appreciated.
G
Gunner
I thought about that, too.. possibly some air smog pump holes, etc
just seems like the original engine.. I'll look into it....
Thanks
Biff
Gunner,
"GBE 058759" is the cars BODY number not the VIN number. Your VIN number should be on a small black & metal plate mounted directly below the carbs on a narrow flat (chasis rail). A 1967 Midget would have a number like "GAN4U 52390" (first '67 Midget) to "GAN4U 60870" (last '67 Midget). The plugs in the head are indeed for a head that had air injection to 'help' it pass USA emmisons probably off a later car. If your engine is original it's serial number should begin with "12CC-xxxxxx". If it begins with "12CD" then it is an emmisions engine from the factory. This number is stamped near the base of the head at the front on a small flat that sticks out near the hose oulet.
G
Gunner
Thanks
My Vin plate is missing on this car... is it stamped anywhere else on the car or frame? The title has that GBE number on it. My engine number is indeed 12cd-da-h-15609. Thanks!
Biff
Sid,
Look behind the right front shock. Your VIN number less the GAN4U should be stamped in the shock mount plate. You will probably have to remove some crud and paint but it should be there. Another place to look would be the backside of the dash. At the factory the digits of the Vin number were written on them in crayon/grease pencil. Another place to look would be on the passenger side footwell floor just in front of the cross rail going to the jack opening.
G
Gunner
Thanks, Biff
It's gonna be a long journey.. but this car is worth it.. it's well preserved in the places that matter.. almost no rust except a few small places on the lower rear fenders, and that isn't bad, either. Frame rails etc are excellent.
I have clutch problems, but I'll look into the slave cylinder. If I have to pull the engine to change the clutch, what should I do while I'm in there?
Thanks
Gunner
G
Gunner
I found it!
Stamped on the rear edge of my right front shock mount. I feel like I have brought her all the way home now, and she has a name. GAN4 59259. Doesn't seem to be a "U" in there anywhere. I think maybe the GAN4U were 1968 models. Anyway, she's legal now. She has a number.
Thanks for all the help. I'll need plenty more. Next step: find out why my alternator isn't working... puts out 12.5 volts.
Sid
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 12
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
