Lug nuts Koenig Rewind Wheels
glemon
OK, sorry for such a specialzed and limited topic, but I know some of you run the Koenig Rewinds on your TR6s and TR250s, I have them on mine the acorn nuts do not want to stay tight and loosen as I drive. I am thinking I don't have the right kind of nut, I have looked on the web for specs for this on the wheel but no luck looks like a conical fit, and most all these I see are 60 degrees, I no longer have the package for the ones I fits I notice some have what is called a "bulge" the conical part goes out farther than the hex nut mine don't), is that what I need for the aluminum wheels?, any help or knowledge appreciated, I guess I am sort of a lug nut novice, all the other cars I have owned have had stock set ups and never had to worry or buy anything.
Thanks in advance, Greg
Greg,
Who did you get the wheels from? They should have sold you the right nuts. I use the Gorilla anti-theft nuts on mine and they work perfectly with the Konig Rewinds.
I got mine from Discount Tire Direct. If you call and tell them what type of wheels you have and the make model and year, they can get you the proper lug nuts.
Hi Greg,
I use Spline drive lug nuts on mine and have never had an issue. There is no bulge to these nuts. They do require a a spline drive socket to put them on and take them off so it is essential to carry on in the car with you. I have two, one for the car and one for the tool box. If you go this route, also remember if you have a stock spare (I have a stock steel rim with redline) you will require the four stock lugs for the spare and the stock lug nut wrench as well.
I didn't use this brand but they are similar to these...I found something locally at a tire/performance shop.
https://www.mcgard.com/automotiveproducts/lugnuts/splinedrivelugnuts
Cheers,
Tush
That's what I'm using on my Panasport's on the TR8.
I think I have it figured out, although I have not driven the car yet to see if the new nuts stay put, I had nute which I believe were designed for a steel wheel, and I needed a bigger mating or friction surface because I was digging into the aluminum when I torqued them down.
The second pic shows the increased mating surface pretty well I think.
Maybe others can learn from my ignorance, Brosky I was too cheap to order to install kit from Discount tire, in hindsight would have been cheaper than buying two sets of lugnuts.
Ever notice how car paint looks a lot better in pics on the internet than in real life?, and close up chrome is just the opposite, looks like crap in pics even when decent in real life.
Z Lug nuts for Minitor rims Spridgets 1
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
maxwedge5281 healey road wheel lug nuts Austin Healey 7
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
M bj8 lug nuts Austin Healey 2
F Correct wheels, studs and lug nuts? Triumph 20
R Which lug nuts for Datsun wheels? MG 8
K Shelby Racing Alloys Lug Nuts? Racing 0
K Alloy Wheel Lug Nuts? Triumph 3
M Spridget lug nuts? Spridgets 1
pjsmetana I got New Lug Nuts... Triumph 5
M What size are the lug nuts on a BE? Spridgets 2
losmorob Looking for Mag Wheel Lug Nuts Spridgets 6
kyreb1862 MGB Lug Nuts 77 MGB MG 3
NutmegCT minilites and lug nuts Triumph 8
R Lug Nuts for Riley One-Point-Five Restoration & Tools 1
John_Mc Lug nuts Triumph 4
R6MGS XK8 Lug Nuts Jaguar 0
V Lug nuts for Panasports Triumph 8
PGSberg TR6 Replacing Trans Fill Plug with Hex Head - NPTF or BSPT threads Triumph 6
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A Odd cylinder head core plug (picture). Triumph 7
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
SNClocks Electrical Wire Lug Spridgets 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
K For Sale Rare TR3 Folding Lug Wrench Triumph Classifieds 1
HealeyRick Plug Your Pipes! Austin Healey 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
