    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Looking for Mag Wheel Lug Nuts
losmorob
I have a '67 Sprite with a set of old Appliance slotted mag wheels. I'm looking for lug nuts. 5 would work, 16 would be great! It's the standard 3/8x24 thread, but the shank needs to be 1/2" outside diameter. Most everything out there is wider. Moss, Victoria, Mini Mania and yes, The Guy ON E-Bay has the wider version. Probably to fit current Minilites, etc.
The nuts that I have use a 5/8" socket and are stamped Spitfire, Sprite, Midget on the sides.
I guess I could drill the holes larger in the Mags, but I really don't want to do that as they're original.
Checked a couple of classic restorer shops nearby and a tire guy that's been in business since the 60's. No luck.
Suggestions?
Ran into this problem with my Appliance wheels on my GT6. Took the wider wheel nuts to the machine shop and had them turn them down to size. I too did not want to drill out the holes.
Try Pack Racing Products. They have a website, but you should call them on that. I have gotten some MG lug nuts from them before. They sell varoius alum wheels.
Think I might have some 11/16"? (USED, but not stripped)
Would they work?
Steve
You say the thru holes in the wheel are 1/2"? With a 3/8" diameter stud that's only 1/16" wall thickness (per side). I also have a set of these same style wheels with the ½” (roughly 17/64”) hole thru. After a bit of a search the simple thing will be to open up the holes to except the current diameter of stem on the lugs available. It’s a safe thing to do given the thickness of the wheel. Sorry I couldn’t give an answer as to where to find them but after facing the same challenge it started me thinking maybe the size was increased for safety reasons along the way?
“dug”
I think the size was increased so the same diameter lugnutcould blank be used for both 3/8 & 1/2" Thus the same wheel could be used as well on 3/8 or 1/2" cars.
I'm thinking of having a set of nuts turned.
Thanks for the offer Steve. I do appreciate it.
Give up trying and send the wheels to me instead.
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
