Lug nuts for Minitor rims
zp28dz
I received some scratch and chip new wheels for some work I did for a friend. They came with one cap, no lug nuts and some chips and scratches. I have a sugeye in dire need of some sidewall to keep the car off the ground. I decided to use these rims, but need lug nut info. They are in storage and I need specs to order lug nuts.
First I know they require 3/8 24 to match the studs. Question is, what is the configuration.. are they mag wheel shank style shouldered with a boss to center them or are they centered by the a matching taper to the contact surface? If shouldered, what is the diameter and length of the barrel which fits in the bore? If conical tapered, what is the angle of taper. I see a lot of lug nuts available for ATVs listed as 60 degrees. Is that correct?
Maybe the question is, who has them.. I don't see much info online about Minitor rims anymore. I have seen a lot of cars with them in the past, so someone should know what I am asking about. They were popular as were the Panasports.
Thanks, John
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
maxwedge5281 healey road wheel lug nuts Austin Healey 7
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
M bj8 lug nuts Austin Healey 2
F Correct wheels, studs and lug nuts? Triumph 20
R Which lug nuts for Datsun wheels? MG 8
K Shelby Racing Alloys Lug Nuts? Racing 0
K Alloy Wheel Lug Nuts? Triumph 3
glemon Lug nuts Koenig Rewind Wheels Triumph 5
M Spridget lug nuts? Spridgets 1
pjsmetana I got New Lug Nuts... Triumph 5
M What size are the lug nuts on a BE? Spridgets 2
losmorob Looking for Mag Wheel Lug Nuts Spridgets 6
kyreb1862 MGB Lug Nuts 77 MGB MG 3
NutmegCT minilites and lug nuts Triumph 8
R Lug Nuts for Riley One-Point-Five Restoration & Tools 1
John_Mc Lug nuts Triumph 4
R6MGS XK8 Lug Nuts Jaguar 0
V Lug nuts for Panasports Triumph 8
PGSberg TR6 Replacing Trans Fill Plug with Hex Head - NPTF or BSPT threads Triumph 6
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A Odd cylinder head core plug (picture). Triumph 7
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
SNClocks Electrical Wire Lug Spridgets 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
K For Sale Rare TR3 Folding Lug Wrench Triumph Classifieds 1
HealeyRick Plug Your Pipes! Austin Healey 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
