Leaf Spring Re-build Options?
About ready to re-install the rear leaf springs on a 1954 Morgan +4, noticing that they appear to come apart quite easily with the u-strap and bolt clamping system and am wondering what the collective wisdom is with regard to disassembling and restoring these. Don't appear to be damaged in any way.
I have seen opinions to put thin strips of Teflon tape between the leaves; a thin coat of chain lube or gear oil; do nothing but clean the surfaces and leaf them alone.
All thoughts welcomed,
BCB Bill
TR3driver
Great Pumpkin - R.I.P
I'm assuming your Morgan springs are similar to my TR3; in which case I would suggest disassembly for cleaning then a coat of some sort of lube. The TR3 manuals suggest used crankcase oil for periodic spring lubrication, but I see no reason that chain lube wouldn't work as well or better.
Years ago, I asked a local spring shop about Teflon for the springs in my motorhome, and was told they did not recommend it as it would cause the leaves to break. I was doubtful, but followed their recommendation instead (which if anything, made it ride worse). But my experiments so far with TR3 springs and UHMW (teflon tends to distort and squeeze out over time, UHMW is almost as slippery and holds it's shape better) seems to agree with them. Of course, it's tough to be certain that a given spring would not have broken anyway, I've broken a fair number without any Teflon or UHMW. And the whole point of the Teflon would be to soften the ride, which means more spring excursion (for a given bump) and it might just be the extra movement shortening their life.
PS, it's also possible that I need to be more careful about tightening the U-bolts evenly. I've been just running them up with an impact gun, but next time I'm going to use a torque wrench for final tightening.
dklawson
On Spitfires there are holes in the leaves where rubbery contact buttons were originally installed. A common fix is to buy or make UHMW buttons to take their place. Filled nylons are also sometimes used. As Randall said, Teflon is not a good choice for this application as it continues to flow and distort under pressure.
There are commercial strips you can fit between the leaves but I have not tried them. Take a look at the product in the link below.
https://www.speedwaymotors.com/Leaf...3-4-Inch,2079.html?OriginalQuery=91033036-BLK
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
F TR2/3/3A Leaf spring advice Triumph 16
Editor_Reid Unusual Leaf Spring Austin Healey 4
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
B BJ8 leaf spring Austin Healey 2
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
C Leaf spring length Austin Healey 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
T TR2/3/3A Leaf Spring "Silent Bloc" Triumph 3
stuntflyr Leaf spring toe-in modification viability Austin Healey 19
H rear leaf spring to chassis bushing Austin Healey 11
simon1966 Leaf Spring Refurbishment 100 BN1 Austin Healey 3
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
D Bugeye leaf-spring removal Spridgets 2
TulsaFred Leaf spring restoration Spridgets 9
RCarr removing a leaf spring Austin Healey 7
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
richberman how to: leaf spring bushing replacement Austin Healey 13
M need help new threaad 1/4 leaf spring Spridgets 6
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
aeronca65t Leaf Spring Re-Arc fixture Restoration & Tools 3
T Two quick leaf spring and bushing questions Spridgets 9
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
tahoe healey leaf spring direction Austin Healey 8
tahoe healey leaf spring instaltion Austin Healey 14
prb51 leaf spring squeek Triumph 10
N Rear leaf spring brackets Austin Healey 9
T MGB-GT what is the length of mgb leaf spring,pin to pin MG 2
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
1965_MGB Leaf Spring Repair? [SFL] MG 6
Atrus Leaf Spring Front Bushing question Spridgets 6
Stig TR2/3/3A TR3 leaf spring maintenance Triumph 4
