TR2/3/3A Late 57 Production with a Small Mouth Apron
mastaphixa
Bronze
I recently purchased a 1957 TR3 with a commission number that places it well within the range of cars that should have been built with a large mouth apron. It has a small mouth apron. The obvious reason would be that it was replaced. I have also heard that as that transition in production was underway there were small mouth aprons left and some cars were produced with them. Any validity to the latter?
Also, the commission number TS 26005 has no drive side designation. I would have thought there would have been an L at the end of it. Thoughts?
Cheers
Steve Baker
Geo Hahn
Absence of a letter L at the end of the commission number originally indicated that a car was built RHD (right hand drive) -- those did not get an 'R'.
It is possible this car began life as a right hand drive car and was converted, calling into question the originality of the front end.
Also possible (and a lot less work) is that a commission plate from a (later) RHD car was used on an earlier LHD body.
If you are comfortable posting a photo of the commission plate - there may be some tell-tale signs if it has been swapped - in particular the rivets used.
TR3driver
Great Pumpkin - R.I.P
Also look at the front inner fenders (aka wings) behind the turn signals. "Wide mouth" cars have a big indentation in the sheet metal to clear the back of the turn signal body; which is in a slightly different place than the hole used on "small mouth" cars. (The flat faced "small mouth" turn signal lamp body extends farther back than the "beehive" lamps used on later cars.) Also examine the bottom edge of the inner wings, where the bumper supports pass under; for signs of the edge having been modified.
Strange things did happen at the factory sometimes, so nothing is impossible; but it seems more likely to me that something has been altered after the fact.
Does it have the locking handle on the trunk, and exterior door handles, and the 3A style interior door panels?
Andrew Mace
One other thing to look at would be the body number plates, especially the "EB" plate. It won't match the commission number but it shouldn't be vastly far away from the commission number. Same, too, with the engine number (assuming the engine is original).
M
mastaphixa
Bronze
Randall, yes to all the door/trunk handle questions. I'll have to check on the other details you have given me to check.
M
mastaphixa
Bronze
I am including images of the data plate showing the commission number. I think the L is there, it's just way off to the right. I also an image of the engine sn and a shot of the front of the car. Thank you all for your time.
Geo Hahn
You are right, the L is there. The rivets also look correct (original). Mine:
Are the body tags on the car?
A Heritage Cert may tell you more about the car & engine's history.
Mickey Richaud
Data plate is the style for the TR3A (smaller; the TR2's and 3's had larger, square plates like this one: 458750-Large.jpg ). And since you have door and boot lid handles, it's likely someone replaced the apron at some point.
ckeithjordan
The commission plates changed from the large octagonal ones to the rectangular plates in 1957. There was an interim style of plate that year, commission numbers TS19XXX, where they took the large one and trimmed off the bottom (see attached photo). My 1957 TR3, TS20447L (built July 1957), has a rectangular plate. Speculation by the Triumph Register folks in the UK is that the trimming occurred because the patents listed on the large plates were no longer valid, so they eliminated that portion until rectangular commission plates were introduced. No other plausible explanation has come up.
Mickey Richaud
CJD
According to that Piggott book tr3A did not happen until TS22014.
Yep, that takes Mastaphixa’s car out of any possible transition range. The apron was changed by someone who liked the small mouth more. The good news, if you want to go back to the “original” widemouth, your small mouth apron will bring more money than the widemouth will cost!?!
Also, the far right L is typical, as I don’t think they knew which drive the bodies would have until after the plate was attached. The L was added later.
M
mastaphixa
Bronze
It all works for me, because I really like the small mouth better anyway. I wanted a '57 because I'm a '57 and I wanted a small mouth. I'm not concerned with the originality. I find the history of these cars part of the attraction. Thank you all for contributing to this thread!
TR3driver
Me too. Enjoy the car!
Me three! My 56 actually came to me with a wide mouth apron; took a fair amount of effort to convert it back.
groupdeville
And me four! You'll also find that the early-style nose requires less work to remove and replace when the inevitable radiator neck leak happens and the radiator has to come out for soldering. The early style nose can come off with the front bumper assembly left undisturbed, versus having to remove bumper components to take off the wide-mouth nose.
TR3driver
I'm hoping I've found the permanent fix for that leak. The radiator shop laid 1/8" soft copper tubing across the joint and soldered it on both sides. Seems to be holding up very well.
R 3-point seat belts on late production BT7 MKII Austin Healey 7
V Late production classic minis: anyone have one??? British Motor Corp 5
V MGB Replace late intake manifold angled breather with early model straight? MG 1
C What to do with my late father's Healey 100 Austin Healey 5
K TR6 TR6 late rims wanted Triumph 0
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
T TR4/4A Recommendation on top for a late TR4A Triumph 8
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
Alfred E. Neuman Late Healey 3000 Spotted 0
JPSmit Late night Benz [no pics] Other Cars 3
B Wanted Late TR6 Gearbox frame Crossmember Triumph Classifieds 1
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
L For Sale late tr4a IRS project Triumph Classifieds 0
T TR2/3/3A Early/Late Starter? Triumph 6
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
Marvin Gruber Mounting info needed for late BJ8 license plate holder Austin Healey 9
S Late 1930s Business Coupe Other Cars 1
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
B TR4/4A Late TR4A - Anyone know what this is ??? Triumph 10
Joe Reed MGB DIY Late MGB Mud Shield MG 0
eschneider Any late-model Mercedes owners willing to review new brake pads/ rotors? Other Cars 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
Keoke SEE it is never too late Austin Healey 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
wkilleffer MGB brake light switches of late Restoration & Tools 3
Mickey Richaud Early [late 30's?] 10 Spotted 0
B TR6 Vacuum retard late TR6 Triumph 4
B TR6 Is the "separation tank" in late model TR6's necessary? Triumph 5
G Late model head light circuit Spridgets 3
af3683 TR2/3/3A Late TR3 Starter Triumph 3
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
6TTR3A TR2/3/3A Late TR2 Grill surround Triumph 12
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
D Late to early bumper swap Triumph 10
dklawson 150 CD Carb Floats - Early vs Late ? Triumph 2
wingsandwheels TR6 Late TR6 Wiper/Wash Switch Triumph 0
Geo Hahn TR4/4A TR4 / late TR3A Starter Pinion Triumph 4
F Late BJ7- any close to mine? 25281 Austin Healey 14
S TR2/3/3A Late TR3A windscreen Washers Triumph 7
