Keihin [Harley] CV Carb Up-date
bill_powell
Keihin [Harley] CV Carb Update
As some of you may remember, I have picked up a (late) '69 Midget with a Keihin CV carb installed. I promised to keep you all updated, so here we go.
The car had an MG Metro type cast intake/exhaust manifold, which had a loud exhaust leak.
I have since installed a Winner's Circle LCB and a single 1 3/4 SU manifold (Mini Mania C-AHT770A). The carb will need some adjustment with this set up, as I have a bit of surging. I will keep you all updated as I make changes.
Now that the exhaust leak is no more, I notice a rather noisy valve train (tapping), so that must be dealt with first.
Here are a couple of shots as she stands now:
Cheers! :laugh:
Re: Keihin [Harley] CV Carb Update
As my pappy always said, "Noisy lifters are happy lifters" ...of course he was almost deaf. :wink:
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
AngliaGT Harley Hearse Spotted 10
T Which Harley-Davidson Muffler for a BE? Spridgets 3
T Harley-Davidson mufflers on a Spridget Spridgets 14
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
simon1966 Austin Harley! Austin Healey 3
drooartz Question on Bugeye Harley mirrors Spridgets 28
G Anatomy of a Harley muffler Spridgets 63
B Anyone need a Harley muffler? [NFI] Spridgets 7
BugeyeNJ58 Harley Muffler Users - did you remove center plug? Spridgets 3
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
sqbsprite Today's Project-Harley Muffler Spridgets 25
boxfullofyertoys Looking for a Harley muffler Spridgets 54
SilentUnicorn Harley muffler Spridgets 16
vping Not British but who can help me with a Harley? British Motorbikes 5
tony barnhill Harley vs Triumph British Motorbikes 8
tony barnhill Not British - but a Harley Question British Motorbikes 4
JPSmit Midget with Harley Engine! Spridgets 6
Sherlock MG Midget... Harley Davidson engine? MG 11
K TR2/3/3A The carb linkage "bell crank". Triumph 9
Govtslug TR6 Carb Problem Triumph 8
W 2024 HD8 Carb Rebuild Austin Healey 4
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
J Spitfire Carb Conundrum Triumph 3
J Spitfire SU Carb Jet Assembly Seized Triumph 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
