Jacking and axle stands
drooartz
I have need to get the Tunebug up on stands this weekend to work on the brakes. I noticed this thread from the Austin Healey section:
#189553
That talks about jacking a big Healey, and the dangers of using the front cross member as jack point. I've got a standard big floor jack--what should I use as a safe front point for jacking? And should axle stands go under the spring pans up front as mentioned in the thread?
First of all, I'd only do one end at a time for safety. I place a 2x6 under the the front crossmember so that the load spans the frame rails. I place the jack stands under the frame rails close to where they go into the tub. It'll make sense once you start. Above all be careful. HTH
Drew, I put the rear stands under the spring mount boxes.
Fronts go where Trevor puts his. I don't have any problem with putting all four corners up at once.
Jeff
It depends on the jack stands. When I'm at my father's shop where I have access to wide base stands I don't mind having all four corners up. However, with my cheap jack stands I'm kind of leary of it.
Trevor,I don't own any cheap jackstands. I did once, 35 years ago, and spent an interesting couple of hours pinned beneath a TR4A. /ubbthreads/images/graemlins/frown.gif
Never again.
Jeff
Roger that. No "cheesy" jackstands!
Better jackstands is on my tool list, but when our local club has done "wrenching parties", I'm shocked at how many people have even flimsier stands, and don't think twice about getting under a car with them. ...runonsentence
My methods have been stated above in places, but I go rear first, stands under the axles as far out as possible so that I can creep under the middle parts easily, then I use 4x stock across the frame members to jack up the front, and put the stands under the frame members with 2x wood "plates between the stands and the car.
I also hold to the rule of never being under a car when no one else is around.No matter what jack stands are available.Wouldn't want stuck for hours underneath,that's for sure!
One other thing:
Raising: Back First, then Front
Lowering: Front first, then back.
This prevents the fuel tank from hitting the deck if the angle gets up there. the Previous owner of mine found this out the hard way. I have since replaced my fuel tank.
Thanks all for the tips. I was planning on using a wood-buffer between jacks and cars on the front--nice to hear I was on the right track. Good reminder as well to stay out from under the car with no one around. Errors there would really suck!
As long as you gents are talking about cheap jacks stands:
https://tinyurl.com/qc28c
Now that is just plain scarey!! /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/eek.gif
Ed
Jackstands? You guys actually paid for and use good quality jackstands? Check out this picture for a better alternative.
That's a Darwin moment waiting to happen. Geesh. Ingenuity is to be commended, but that might be pushing it a bit too far!
I had a pair of those, just gave them to a friend and got the 3 ton versions. 6 ton ones were just a bit too big for my old TR4, took up a lot of space under there. The 3 ton ones are still nice, but a wee smaller and shorter. Seems a better fit for the little Tunebug
Woodie jacking and axle stands Spridgets 4
T Bugeye rear jacking point not including axle Spridgets 3
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
X BE jacking tube access holes and top bows. Spridgets 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
W Jacking OOPS Jaguar 1
W Etype Ser. I front crossmember jacking Jaguar 3
GTP1960 TR2/3/3A Jacking up a TR3A Triumph 31
CJD TR2/3/3A Jacking Without a Wood Block Triumph 12
bugedd Jacking up the car Spridgets 29
B TR6 TR6 Engine leaks, jacking questions Triumph 9
M jacking point rocker debris Spridgets 3
B Race spridget weight jacking Racing 8
S Healey jacking points and jack stand placement Austin Healey 13
bigjones Jacking points for one side of Midget Spridgets 8
V TR2/3/3A Jacking up a TR-3B Triumph 4
R Jacking question MG 6
G Jacking Plate Triumph 2
A Jacking Points '59 Bugeye Spridgets 5
D Jacking Points Jaguar 3
7 Jacking and Jack Stands Austin Healey 25
S MGB Jacking an MGB MG 21
A "jacking" up prices Austin Healey 27
SpannerMan TR4/4A TR4 floor jacking holes... fact or fiction? Triumph 11
Y Jacking points and jack stand placement on Europa Lotus 1
martyc T-Series MG TD Jacking/Jack Stand Points? MG 4
Patton Jacking Points [ to Avoid Frame Damage ] Austin Healey 15
G Jacking problems.... Triumph 3
A Jacking my midget? MG 17
J E Type Jacking point Jaguar 7
B MGA Axle Brake line MG 0
B MGA Where to Buy, What to Buy? Axle Nut MG 9
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Rear Brakes and Solid Axle Triumph 2
A Wanted Girling Axle for TR2 Triumph Classifieds 5
drooartz Bugeye jack points to remove rear axle Spridgets 18
R BJ7 Rear Axle Maintenance Austin Healey 5
SNClocks Bugeye axle limit straps Spridgets 5
A Rear Axle Oil Seal Austin Healey 4
Lin Bugeye Axle Hub & Bearings Austin Healey 1
P MGB Tube axle wear MG 3
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
CJD TR2/3/3A Lockheed Axle Triumph 8
