i'm almost there
jmayzer
Member
so i found a gearbox up in delaware, hooked it up to the engine, put it all back together and now, naturally, the problems start. the gearbox is locked up. at first i thought it was stuck in gear, but if i push down and then to the right really hard, i can get it to knock over, but not down actually into reverse gear. so as far as i know, i'm in neutral, but if i try and spin the driveshaft, rear wheels at the same time, rock the car back and forth, i get nowhere but a couple inches in either direction.
now the master cylinder had been emptied because i had to replace the slave cylinder and still need to replace the front brake lines. i have not yet bled the clutch line...that wouldn't make a difference, would it? i'd really like to discuss this whole issue over the phone with someone who has the time and familiarity with this year car. PM me for my number if you'd like to chat/could be of some help. cheers.
jake
Deleted member 8987
Usually you at least roll the input shaft, checking output, in all gears before you even buy it, or at least before you install it. If I was to fathom a guess, somebody had the top cover off and something has shifted on one of the forks. You should not need hydraulics if you don't have a load on the gears...like the car has rolled down or uphill.
Others will chime in shortly, but I think you're going to have to pull the top cover with the box level and see where the forks are...then look at the gears...then see what is locked visually...
aeronca65t
Agree with TOC. The forks are probably in the wrong position.
This can sometimes happen if someone takes the side cover off (the top cover only exposes the rear part of the shift linkage) and fiddles with the forks. Also, when the side cover comes off, there are two little springs and ball-plungers that can shoot out so you have to be careful when removing.
If you are lucky, sometimes the edge of two synchros is caught in their respective gears at the same time. A little joggling with the shifter while rocking the car might fix things but it should not require a lot of force.
But that's if you're lucky......
I have an old racing friend who tells me he can pull the side cover while in the car and move the forks but it looks like a very difficult job. I just put an engine/ trans in my race car this morning. No fun but you may end up pulling the engine/trans out in your's.
Bob Claffie MGA Almost barn find MG 1
Jim_Gruber Remember "The Mite" a beautiful "almost a BE" Build. It's back on BAT and Badder than ever! Spridgets 6
AngliaGT Miata - ALMOST Made it Home Other Cars 7
tinman58 General TR Finally almost Triumph 7
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
Marvin Gruber TR4/4A Almost a burnt run Triumph 12
Jim_Gruber Rear End almost out Spridgets 5
glemon The E I almost bought Jaguar 10
D TR4/4A almost have a good radiator..but... Triumph 8
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
Rob Glasgow I met my goal, well almost.... Austin Healey 7
TulsaFred Bugeye garage paint job - start to finish [almost] with lessons along the way Spridgets 28
Bob Claffie Almost an AH Austin Healey 0
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
D Dash Recovering - Almost done Spridgets 32
S Almost Entered my First Show Spridgets 4
S The [Almost] Perfect Day Spridgets 5
7 Post-War Other Hope I haven't bitten off more than I can chew! [the body is almost off] Triumph 5
D Almost ready to start roller paint job Spridgets 4
A almost screwed up Triumph 8
D Almost ready for paint Spridgets 16
D Front suspension and steering done - almost Spridgets 18
AngliaGT My New Cortina - almost Other British Cars 14
M TR2/3/3A TR3 paint is almost done Triumph 10
P Finally after almost 20 years! Austin Healey 1
KVH Overdrive Almost Ready Triumph 5
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
J ALMOST got the windshield in! Spridgets 12
M Back In The Saddle [almost] Spridgets 6
N First startup in almost 30 yrs, a no-go Austin Healey 19
D Almost legal Spridgets 18
M almost done Triumph 10
M Tub Almost ready to come off [pics] Triumph 10
R I Can Almost Smell the Paint Spridgets 8
glemon TR5/TR250 TR250 Almost Done, Pics, Thanks for the Help Triumph 22
mrsprite My Bugeye almost burned down today! Spridgets 20
mountainman Finally after 2 1/2 yrs It's almost finished Triumph 37
I Bugeye heater cable almost repaired, but need help Spridgets 4
hondo402000 TR6 TR6 Painting Journey almost over Triumph 9
jvandyke another almost stranding Spridgets 4
SkinnedKnuckles Spring's almost here Triumph 4
T Almost looks stock - really nice build Triumph 8
T Almost seems a shame to paint them Spridgets 16
G Never buy a tube of grease AGAIN!!! [well, almost] Spridgets 7
theleisure Almost 5 o'clock, what are your weekend projects? Spridgets 21
Johnny BJ7 Almost completed..... Austin Healey 14
mjobrien 100 - Almost there..... Austin Healey 14
NutmegCT TR2/3/3A Almost 40 years ago - a TR3 Triumph 4
ChrisS Almost dropped a valve Spridgets 7
bighealeysource ALMOST burned up my wiring harness Austin Healey 14
