Never buy a tube of grease AGAIN!!! [well, almost]
G
Long story short, went to grease my frontend today and made two pulls on the trigger and no grease. I live WAAAY out of town,; don't feel like running in to buy a tube and Adavance doesn't deliver here on Saturday (commercial acount).
No tube grease anywhere, but I do have a fresh, full TUB for hand packing, Figures, I always have what I don't need at the time.
I hate grease, hate it on anything, especially my hands, so I'm not looking forward to spoon feeding my air grease gun.
Suddenly it hit me, "just put the end of the tube body from the gun in the TUB of grease with the empty tube still in it and pull the rod back".
V'ola !!!!! About half a tube of perfect air free grease !!!!!
Just a little to wipe off of the end, reinstall and bleed as normal.
Granted, it's not all the way full, but it'll get you where you need to be.
You can fill it all the way if you want, just make sure you stop BEFORE you reach the bottom of the TUB (got stuck there), and push the other grease to the middle and keep pulling back.
I'm so happy, I feel like the kid who made the flat bottom tacos.
Hmmmm, I might bring my wife to the Mexican joint for lunch.
I'll definatly be able to score some grease there !!!!!
Something tells me maybe this is how it was done before tube grease came to be, but that's before my time. Probably some guy thought "hey, let's put grease in a tube", and then they all went for tacos.
Before you had replacement tubes, that's how we reloaded grease guns.
Used to do it every day.
You will learn to bang the can to pop the air bubbles out and settle it, the tap the gun case to do the same.
Put the case up, loosen 1/2 turn or so, and release the plunger.
That will pop most of the air out around the threads...and when it is obviously grease, quick tighten it.
Mine has a bleed on the top but it doesn't work right. I keep the hose a little loose and just pull it off and use my finger over the hose and bleed like that.
Yes, kinda, as long as it does not leak.
<span style="font-family: 'Arial Black'">You will learn to bang the can to pop the air bubbles out and settle it, the tap the gun case to do the same.
That will pop most of the air out around the threads...and when it is obviously grease, quick tighten it.</span>
So you can eat more tacos!! :cheers:
the tacos were most delicious too !!!!!!
......although they didn't have flat bottoms.....nor did they bring me nails and a hammer.....
I guess they didn't know the little boy or see the commercials.
Stupid me, the commercials are in ENGLISH !!!!!
( these are "fresh out the truck" folks we're talking about).
Ya know, leave it to us Americans to screw up perfectly good ethnic foods. I've eaten at SEVERAL "Mexican" places here, and HATED Mexican food........until I went to a small Mexican town (pop 1500) and MAN, TALK ABOUT GOOD FOOD !!!!!!!
......all this food talk is makin' me hungry again. I guess I better do something clever so I can get some more tacos.
Chips and salsa and and some good tamles and a cold beer sound good now .
Later I'm headed to Dos Choaros for Diner!
mctriumph General TR They are never DONE!! Triumph 5
mctriumph General TR NEVER start a car with stale gas Triumph 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
AngliaGT MGB-GT I Never Thought of an MG as a "Cookie Cutter" Car 'til Now MG 3
69MGC T-Series Never thought I'd switch MG 5
R General TR Emergency hot wire - because you never know whats next Triumph 2
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
F TR2/3/3A RULE#1 Never throw anything away Triumph 3
Gliderman8 General MG The car that never was MG 6
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
D never throw old parts away.... Austin Healey 7
doc50 TR2/3/3A Never seen a TR3 with this feature. Triumph 2
CZ_Dave MGB Ya Just Never Know What Cha Find MG 5
drambuie You never looked so good! Austin Healey 9
mrsprite Old Spridgets never die... Spridgets 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Keoke SEE it is never too late Austin Healey 3
JPSmit Bring a Trailer - I never even knew this existed Spridgets 4
DNK Never Seen One of These Before Other British Cars 3
Sherlock Betcha never heard of this one... Other Cars 6
hilsideser Never seen one of these before... Spotted 5
AH67 facet fuel pump never stops ticking. Austin Healey 6
Jim_Gruber Never throw anything away!! Spridgets 7
DNK Never saw that... Triumph 0
Mickey Richaud Never Seen One of These Sunbeam (Rootes) 0
bighealeysource Never been in a Concours - what do I need to do ? Austin Healey 22
G Never give up hope ! ! Triumph 2
HealeyRick Sunday Will Never be the Same Austin Healey 0
JPSmit Never seen one before Other British Cars 8
drooartz Never been so happy to have a speedo die MG 0
MCNX_BFF Triumphest 2010 pix --Better late than never? Triumph 4
PATR8 I know why I never have time to fix my stuff Triumph 6
JPSmit I've never seen one of these for real Spridgets 5
drooartz Why you never throw anything away Spridgets 16
T Never quite know what you are going to find... Triumph 14
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
Hap Waldrop Beer run pics, better late than never :] Spridgets 6
Jer you never know... I just bought a Bug Eye ! Spridgets 21
Jer never know who you will meet at a car show... Spridgets 4
DNK It never ends. Triumph 12
glemon Never Assume [Ignition Timing] MG 1
M TR2/3/3A NEW MEMBER INTRODUCTION BETTER LATE THAN NEVER TR3 Triumph 19
Jim_Gruber Never overlook the simple stuff Spridgets 1
JPSmit It never rains, it pours Other British Cars 12
T Never seen one of these.... MG 11
C Better LATE than NEVER! Triumph 18
PHerder Never know what you will find in the trans tunnel! Spridgets 14
S Here's a TR variant most have probably never seen Triumph 7
