TR4/4A Hole in my firewall
SpeedyG
When I acquired my 1966 TR4A it had a large hole cut out in the firewall / passenger footwell area (picture attached).
It has four small holes around the outside of it like something was attached here at one time.
Does anyone have any idea what might have gone here?
Thanks for helping.
Ed
Wouldn;t two of those holes be for the body number plate? I'm pretty sure mine is in that area (albeit RH drive) - longish plate with 5 digits stamped on it (eg 12917) and riveted to the firewall in that area.
Yes the two holes on the top flat are for the number plate which is off while restoring the car. The hole I am referring to is the approximately 4" x 6" hole on front of the firewall. I'm sorry I posted the picture kind of at a funny angle.
But surely the big hole you mention is for the clutch/brake levers to protrude on a RHD car, linking up to the master cylinders which would mount on the horizontal platform of the firewall. Either someone previously took the blanking plate off for some reason or possibly yours has been converted from RHD - although why they wouldn't carry the blanking plate across is not clear?
Edit: Whoops - apologies, the brake/clutch levers emerge through the horizontal platform of the firewall directly to the master cylinders I've just looked at my (RHD) 1962 TR4 in Australia - it's got exactly the same blanking panel that NutmegCT posted! Bit of a mystery then!
There was dealer installed AC and the lines could have well been routed here.Latter when the motor
was burned up it was abandoned for the bad idea it was.(not common but I have seen it)
Mad dog
Or maybe someone got really frustrated when the hood latch failed 😆.
Kidding - the cut out looks clean, including the four mounting holes, so it must have been on purpose. A/C, speaker both make sense.
There is one bolt visible in your picture, in one of the four holes. What is this currently holding?
Bingo! It is a AZ car... There is no other remnants of an AC system but that sure could be it.
Thanks! I still have to wedge in that V8... Just kidding! :ROFLMAO:
It's definitely convenient for a hood latch stuck problem. :unsure: I will be making a blanking plate however.
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
rlandrum TR2/3/3A TR3A Firewall Hole Spring Clips Triumph 8
CCURTISS T-Series MGTF Firewall [what goes in what hole] MG 2
S How to seal the square hole in the firewall Triumph 14
R GT6 GT6 speedo cable: which firewall hole? Triumph 3
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Rocker panel hole Triumph 16
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Strange hole! Triumph 5
J TR2/3/3A Hole in Rear Hub Triumph 7
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
R TR6 Trunion Hole Triumph 2
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
R TR2/3/3A Timing hole alignment Triumph 1
D TR4/4A water pump mystery hole Triumph 6
T TR6 What's this hole for? Triumph 5
wingsandwheels MGB new project...need like a hole in the head MG 8
S TR2/3/3A gas tank hole body work Triumph 7
T Grommet - sling hole in floor - XMSC108 Spridgets 3
R Plug bell housing/clutch housing hole? Austin Healey 10
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R water pump small hole does line up Austin Healey 7
Griz What is this hole for? Austin Healey 10
L What is this mounting hole for ? Spridgets 7
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
cmacmillan TR6 75 TR6 Weep hole weeping.... Triumph 2
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
