TR6 What's this hole for?
TR666
After removing the water pump housing, I noticed an opening in the block directly behind it. You can only see a crescent shaped portion of it, since the remainder is behind the front plate. If you look at a Bentley manual on page 112, it is shown on the lower illustration between the reference numbers 5 and 9. Should this just be an open hole into the block or should there be a plug there? I should mention, I bought this car as a non-running vehicle and has not been running since the mid eighties. So, I couldn't tell you if coolant or oil had come out of there. I haven't been able to find any pictures of just the front of a bare block. Any ideas?
poolboy
Go to page 129 in Bentley illustration 12.41.00 sheet 1
Using the dowel (9) as a reference, I think you'll see a freeze plug in that location.
poolboy
Go to page 129 in Bentley illustration 12.41.00 sheet 1 and compare to page 112.
I have a block in storage that agrees.
T
TR666
Thanks for that. What's confusing is, if you look at the Moss or TRF plate illustration, there appears to be two openings which is different from the Bentley picture, yet only one plug is referenced and it's not in the location of the opening. Of course they have to obscure the portion I want to see with the end plate gasket. Oh well, looks like I start tearing it apart. Anything else other than timing parts that can/should be replaced while I'm there?
poolboy
There's no telling what all that engine will need if you've never heard it run.
Just take the whole engine apart, save what you can, replace the rest, would be my approach.
T
TR666
That might be the way to go, since it may have been run without coolant if that plug had rusted through while it was still operational. It has about 52,000 miles on it.
K TR2/3/3A Stripped threads in spark plug hole Triumph 14
SpeedyG TR4/4A Hole in my firewall Triumph 12
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Rocker panel hole Triumph 16
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Strange hole! Triumph 5
J TR2/3/3A Hole in Rear Hub Triumph 7
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
R TR6 Trunion Hole Triumph 2
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
R TR2/3/3A Timing hole alignment Triumph 1
D TR4/4A water pump mystery hole Triumph 6
wingsandwheels MGB new project...need like a hole in the head MG 8
S TR2/3/3A gas tank hole body work Triumph 7
T Grommet - sling hole in floor - XMSC108 Spridgets 3
R Plug bell housing/clutch housing hole? Austin Healey 10
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R water pump small hole does line up Austin Healey 7
Griz What is this hole for? Austin Healey 10
L What is this mounting hole for ? Spridgets 7
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
cmacmillan TR6 75 TR6 Weep hole weeping.... Triumph 2
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
K TR2/3/3A Ovalled bush hole in lower A arm front suspension. Triumph 1
S hole for speedo cable Austin Healey 1
S hole for speedo cable Austin Healey 6
AHS TR2/3/3A Dashboard hole identification Triumph 8
