    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A Antenna hole?
Jim_Stevens
We got the TR-3A body back from the sandblaster today, and along with the not-unexpected additional body work that needs to be done, there was a 1” hole for an antenna in the RH part of the cowl, right above the factory hole for the speaker.
A DPO had had a radio in it at some point. I’m wondering if the hole was a factory drill-out as well? Anybody have the same experience? It’ll be filled for sure (no radio for me) — just curious.
When I stripped mine for a respray I found a second antenna hole where you describe (already had another antenna hole in the top of the right wing).
No idea when that hole in the cowl had been filled, never would have known it was there except for a strip to bare metal.
I doubt it was 'factory' - I am not even sure if speaker holes were 'factory' (my 59 does not have them).
Almost certainly not factory. Original radios were dealer-installed for cars delivered in the US. Otherwise, they tended to go missing during shipment.
I've got a copy of the installation instructions, that shows the antenna hole centered 11-7/8" forward of the door seam. But I've seen cars with it in all sorts of places; so it appears that even the dealers didn't always follow directions.
PS, I believe the speaker holes were factory, but only on earlier cars. Deleted in June 1959 according to a memo I've got.
https://drive.google.com/open?id=1UWbjZoV3dbvb22umr6D4TFWOt5ox86jD
I have an early '59 and it has speaker holes on both sides but no antenna hole.
I have a hole in the cowl on the passenger side. 1961 TR3A.
I plan to fill it in as I will not have a radio.
David
At the dealership where I did a brief stint as a mechanic in the early 60's, radio installations were given to the lowest tier of mechanics (me) so about anything was possible.
Tom
I have seen that holes in the cowling before also. I thought maybe a mirror or one of those old school spot lights you can move around from inside.
...Deleted in June 1959 according to a memo I've got...
Nevertheless, no speaker holes in my April 15, 1959 build:
Seems like that is always the case with any change point. Some before the given point will get the change; some after won't get it.
Hard to say what happened here. The memo might be wrong, or perhaps your body got sped up somehow so it was finished (as a car) earlier than other bodies. Maybe there was an accident along the line, so the original body for your car was damaged, and they repaired it by grabbing a body from earlier in the normal process. Might be interesting to know how your "Mulliner's" number compares to other cars around that time.
If you read through Piggott's 'Original TR', he points out many other instances where changes didn't happen exactly as documented. For example, some pre-TS60K cars were built with the post-60K body. And vice versa!
So, I always take change points as being approximate. I quoted the memo more to show that there was a deliberate change (I believe) than because I trusted the date to be correct (especially in terms of being correct in all cases).
Quite true, e.g. mine has no blanking plate on the right side of the firewall but many cars after mine did get one. Ah, the mysteries of STC.
I have an August 59 build and it had the speaker holes but no right hand blanking plate. I had to cut a hole for the pedal box and steering column for the right hand steering conversion, all the other brackets and mounting points were allready in place.
Graham
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
S TR2/3/3A tr3 radio antenna hole Triumph 15
kodpkd Antenna Removal Austin Healey 9
S Radio Antenna Spridgets 5
maxwedge5281 radio antenna location Austin Healey 17
M TR2/3/3A TR3 Antenna Triumph 10
drooartz Out with antenna, in with mirror MG 8
1 Amplified Antenna? MG 9
R radio antenna Spridgets 11
JohnnyO Antenna installation Spridgets 19
M Is this antenna factory Spridgets 7
K antenna location in a TR6 FORUM Navigation Questions 0
K TR6 antenna location in a TR6 Triumph 6
bcbennett Radio antenna lead Triumph 3
T MGB Antenna Access 72 MGB MG 2
D Antenna position Austin Healey 10
GBRandy TR2/3/3A TR3 Antenna Triumph 8
Gliderman8 Antenna Placement Restoration & Tools 11
angelfj1 TR-3A Radio Antenna Options Restoration & Tools 4
2wrench Dropped radio antenna into fender. Triumph 21
G Fully retractable radio antenna Triumph 5
69MGC Removing an Antenna from a 79 MG 8
RSMTR8 Wedge TR8 Radio and Power Antenna Triumph 4
jjbunn Radio Antenna MG 12
RSMTR8 Wedge TR8 Power Antenna Triumph 0
C whip antenna Jaguar 0
Velox BJ8 Antenna Question Austin Healey 3
T Antenna options MG 5
A MGB 1977 MGB Antenna Installation??? MG 4
G radio antenna replacement Triumph 7
S Removing Antenna?? MG 6
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
SpeedyG TR4/4A Hole in my firewall Triumph 12
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
