HIGH BEAM LIGHT Ground Wire
Tinkerman
My TR is a post 60000 commission number car. I bought a new wiring harness from a reputable company. I noticed that on the high beam connection wire there is a small ground wire attached to the high beam light bulb connection. I called the company and was told that because of the plastic sockets it had to be grounded. Apparently the older cars the sockets were metal and self grounded when installed. The wire is about 4" long with a round terminal with a 1/4 " hole. About the only thing I can reach with it is a dash cluster mounting post. Would that be safe to use? Everything else in there that's reachable are larger than 1/4".
Your help greatly appreciated, Tinkerman
TR3driver
Great Pumpkin - R.I.P
I would suggest one of the mounting studs for the speedometer. Close by, and smaller than 1/4". An "internal star" type lockwasher might be a good idea too, to ensure a good connection in the future.
Another solution would be to cut and splice the old socket to the new wiring harness. Given the comments that someone else on this forum made about the plastic breaking, I would be tempted to go that way.
The speedo still has to be grounded for the other lights to work, so you'll still want the other ground wire whichever way you go. Don't try to rely on the bracket's contact with the back of the dash; it may work at first but is bound to get worse over time.
CJD
Along those lines, there should already be a ground wire running from the center instrument cluster to one mounting stud for both the speedo and tach. The same stud that has that wire would be ideal...
John
TR3driver
That's an interesting washer pump you've got there, John, rather different than the one from TS39781LO. Is it original? Do you know what the commission number was?
CJD
Hey Randall...
I don't know if it's original or not. The car is #60732. I had to change the one in the picture out for reman one from Moss, as the seals were shot. You'll see that some PO heated the extra tube and pinched it closed, so I know that part of it was not factory!
How did they usually look?
John
TR3driver
I don't know how they "usually" look. Apparently most of them were dealer-installed, so the dealers may have installed different pumps depending on what was handy at the time. But mine looked more like the illustration below from the TR4 SPC, and had a knob like the one shown on TeriAnn's web site:
R Speedo High Beam Warning Light Color Austin Healey 14
A MGA High beam indicator light not working MG 2
W high beam/engine light MG 7
M high beam light cover Spridgets 13
Carlbanan56 MGB High beam problems MG 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
D High beam Lamp Spridgets 3
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
W BE ignition and high beam jewels... Spridgets 12
W BE ignition and high beam jewels... Spridgets 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
Rob Glasgow High Beam Indicator Color - At last the answer Austin Healey 3
drooartz Moving high beam switch Spridgets 13
T High Beam Headlights Jaguar 1
C One High Beam doesn't work Triumph 5
mjobrien High Beam Switch Mounting [Dipper] Austin Healey 7
19_again Blue high beam indicator MG 8
D High Beam Indicator Always On Triumph 9
T High-beam switch Triumph 2
X no beam/ high beam! MG 6
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
D TR2/3/3A Alternator dial runs high Triumph 5
