Moving high beam switch
drooartz
My Bugeye currently has the standard floor-mounted dip switch for the high beams. I'd like to move this to a toggle switch in the dash to free up some floor space for my big feet.
What do I need to do? The Tunebug currently has a completely stock wiring setup. Can I just extend the wires and add a switch? How many amps does the switch need to carry? Is there a better/simpler way?
Thanks!
Billm
I would do it with a relay but that could get a little complicated (single pole-double throw relay with toggle switch for high beams)
Bill
2091351
Turn it over and remount higher up with the upper screw. Driven lots of miles that way.
Works good!
Steve
Hairyone
oh many amps? lots. headlights on full beam 55W each x2 110w divide by 12v = 9.167 Amps call it 10A a big toggle switch on the dash would suffice but a "change over relay" would be much better: Relay pin 85 to ground. Pin 86 through the dash switch to a switched + i.e. ignition (this will only be very low current). Pin 30 to the light switch pin H, relay 87a low beam, 87 high beam.
I'm currently completely re-wiring my frogeye, adding a 4 way relay block & a bank of 16 fuses (not sure I'll use all 16, but I will use more then the two as originally used). I'm also using a relay to switch on the headlights to save the headlight switch (so this switch is also not taking 10A + wide lights & dash lights). I'm planning later to switch headlights to use 100W full beam bulbs, that'll take my total to 20A. Hence the re-wire as I wouldn't like to put that through the original 50 year old string & later bodged connections.
drooartz
drooartz
Thanks for that info. Relay shouldn't be too hard to wire in.
Midget78
Drew, I didnt realize the bugeyes had the floor switches. My midget they ran it into the windshield wiper arm. Pull the arm toward you and it would turn on the high beams. There is also a blue bezel on the dash that illuminates when they are on. I wonder if the stearing column can be retrofitted to use the switch like what is in the midgets?
drooartz
drooartz
No space on a Bugeye column for a switch. I'm planning on making a small switch panel that would mount under the dash, so I've got space for a headlight dip switch and a switch for the electric fuel pump.
A few nice toggle switches would look properly period anyways. :smile:
walshja
Sweendog, yours is on the wiper switch? mine is on the turn signal switch (I think)
weird
bthompson
For Midgets, it should be on the turn sig switch. Wiper switch was for foglamps on the MGB. If the turn sig switch frazzled in the dim and distant past, I would imagine it's not unlikely a PO re-wired it to the other side.
Platinum
Drew, visit McMaster-Carr and Granger. Look for a DPDT pushbutton. I've not done it but splicing a relay set into the harness after the floor mount one shouldn't be too challenging.
spritenut
You can always use the dash lamp switch, it's already there, nobody turns off the dash lights. Just re-route the wires from the harness where they join for LH drive and run them behind the dash to the switch.
drooartz
drooartz
Great idea to use that dash lamp switch, Frank. I like it.
Sarastro
Just one suggestion--when you're switching DC, especially incandescent lights, it's always a good idea to pick a switch that is over-rated. The lights draw more current at turn-on than when operating, and DC really tends to fry switches. I suspect that most switch current ratings are at least a little optimistic. So, for ~10 amps of lighting, I'd use at least a 15 amp rated switch; you might find only 20 amp switches, though. This'll be one husky motha.
Makes one of those 30-40 amp relays look good!
drooartz
drooartz
My plan now is to use a relay for the high/low switch, with the relay triggered by the dash light switch. Seems the simplest method, really, and doesn't require any new holes in the dash.
Thanks again for all the really great ideas here.
AngliaGT Skip Barber Racing School moving to VIR Racing 2
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
KLUTZ FS. My '64 B, OD, Love it but moving on... MG 7
Sopwith_Camel mg guy moving up Jaguar 31
rlich8 Timing Mark Moving Around Triumph 21
D My B is moving under it's own power MG 10
boxfullofyertoys Moving sale! No reasonable offer refused! Spridgets 2
tahoe healey Moving car with out coolant Austin Healey 5
tomshobby Moving on! Spridgets 4
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
J fender cover out of moving pad Austin Healey 6
T OT - I'm totally bummed. FJR moving to a new home Triumph 13
theleisure Moving North, Looking for '66 Hardtop Spridgets 7
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
Tinkerman TR2/3/3A Moving & Setting Body on the Frame TR3A Lifting P Triumph 10
T The "Sock Zone" is moving into my garage.... MG 1
tahoe healey Moss moving? Austin Healey 12
eejay56 Spitfire Help moving a Spit in Salem Triumph 13
mrstinson Moving and need help Spridgets 8
Trevor Jessie Moving wiper motor Spridgets 6
tahoe healey Dixon is moving! Austin Healey 14
toysrrus toysrus [Russ] is moving to the Jaguar Section Triumph 23
beaulieu moving a car cross-country - by furniture movers? Restoration & Tools 16
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
K TR2/3/3A TR3...Moving the Coil & Petronix Wires Triumph 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
JFS Moving Tool Chest Restoration & Tools 5
kyreb1862 MGB Moving an MGB MG 26
S Car moving/transport company suggestions? Other Cars 20
drooartz Moving on to the generator Spridgets 32
zimmy car is jerky when moving Spridgets 4
soren_ak question regarding moving a car from England to DK Austin Healey 2
Stewart Moving around an MG MG 6
T GT6 moving the body on a gt6 Triumph 4
kindofblue TR5/TR250 TR250 Latest - Moving Ahead Triumph 16
T Moving Gas Tank Triumph 5
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
