MGB Moving an MGB
kyreb1862
I'm sure this has probably been addressed before but, I need to ask again. I am closing a deal this weekend on a 1977 MGB. The car is located about 200 miles from my home. The PO says while it runs he doesn't know if he would trust it for that distance. I don't own a trailer but I do have access to a car dolly. What prep work do I need to do to the car to be able to tow it? /ubbthreads/images/graemlins/confused.gif
Make sure she rolls...and then disconnect the drive shaft from the differential. (You can then tie the shaft up to the bodyshell or completely remove the driveshaft.)
jlaird
Not a good idea to remove the driveshaft, tranny oil will leak out, just tie it up with a coathanger.
kyreb1862
kyreb1862
I also need to ask about the car dolly. The PO says he thinks the car may be to narrow for the dolly. Anybody have any experience with this?
It will be tight on a dolly, but you can do it.
I've never had a problem with a leaking transmission on a tow dolly with the driveshaft removed.
IF it does leak, you can always check the level and top off if needed. With a new purchase, this should be done anyway.
tony barnhill
Great Pumpkin - R.I.P
Put your best tires on the rear & make sure the rear end is full of 90wt..
Jarhead
when I bought my '77 it was a little over 150 miles from home. I had a buddy take me over with a small tool box and enough various fluids to top of the systems. I then drove it home. It was the best way to find out what it was going to need. I was lucky it made it all the way to the garage without a problem, short of mis-firing, coughing and spitting all the way. Ended up putting new ignition and carburation on it. Good luck either way.
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
I used a dolly to drag a Midget home a few years ago. It fit, but barely! I added a couple of washers to each wheel stud to get another 1/4-1/2" of track clearance. I think a Midget is about 4ft.
tony barnhill
If its one of those rental dollies, it'll work.
What is wrong with putting the back wheels on the dollie and towing the car backwords? Wouldn't even have to get under the car.
tony barnhill
Gotta tie down the front wheels then, Kenny...so they track straight
And you CANNOT do that if the car has wire wheels!
Steering lock mechanism won't hold it? - Just curious.
tony barnhill
Might - if he got the tires lined up perfectly straight...otherwise the car will 'crab' down the road & wear out the tread...plus, as mentioned above - if its wire wheels, they could loosen themaselves running backwards
kyreb1862
kyreb1862
Car has disc wheels but the truth is, I have never been comfortable towing one backward. A little more work, but I think I would feel more comfortable taking the drive shaft loose. Also had a thought ( made my head hurt) does U Haul rent trailers you could haul a car on? /ubbthreads/images/graemlins/laugh.gif
sunkissedhealey
Yep, at least U-Haul used to have such trailers 30 years ago. I've rented many car-carrier trailers from them, moving my MGA (had it 20+ years) from California to Tennessee to Washington D.C. and then back again. Give them a call.
Rob
Yes..U-Haul rents car haulers. I don't know if they rent just the trailer without the truck. Do NOT be afraid of a tow dolly. I've used one for an MGA, my MGC, a friend's MGB, all without incident..a couple on treks of 300 miles. Almost easier to use than a trailer....except darned near imposible to back up, as the pivot quite easily.
tony barnhill
[ QUOTE ]
What damage can be done if the driveshaft is not disconnected?
[/ QUOTE ]
Can ruin the front pinion bearing in the rear end.
jlaird
Sure, need a class 3 hitch though.
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
AngliaGT Skip Barber Racing School moving to VIR Racing 2
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
KLUTZ FS. My '64 B, OD, Love it but moving on... MG 7
Sopwith_Camel mg guy moving up Jaguar 31
rlich8 Timing Mark Moving Around Triumph 21
D My B is moving under it's own power MG 10
boxfullofyertoys Moving sale! No reasonable offer refused! Spridgets 2
tahoe healey Moving car with out coolant Austin Healey 5
tomshobby Moving on! Spridgets 4
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
J fender cover out of moving pad Austin Healey 6
T OT - I'm totally bummed. FJR moving to a new home Triumph 13
theleisure Moving North, Looking for '66 Hardtop Spridgets 7
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
Tinkerman TR2/3/3A Moving & Setting Body on the Frame TR3A Lifting P Triumph 10
drooartz Moving high beam switch Spridgets 13
T The "Sock Zone" is moving into my garage.... MG 1
tahoe healey Moss moving? Austin Healey 12
eejay56 Spitfire Help moving a Spit in Salem Triumph 13
mrstinson Moving and need help Spridgets 8
Trevor Jessie Moving wiper motor Spridgets 6
tahoe healey Dixon is moving! Austin Healey 14
toysrrus toysrus [Russ] is moving to the Jaguar Section Triumph 23
beaulieu moving a car cross-country - by furniture movers? Restoration & Tools 16
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
K TR2/3/3A TR3...Moving the Coil & Petronix Wires Triumph 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
JFS Moving Tool Chest Restoration & Tools 5
S Car moving/transport company suggestions? Other Cars 20
drooartz Moving on to the generator Spridgets 32
zimmy car is jerky when moving Spridgets 4
soren_ak question regarding moving a car from England to DK Austin Healey 2
Stewart Moving around an MG MG 6
T GT6 moving the body on a gt6 Triumph 4
kindofblue TR5/TR250 TR250 Latest - Moving Ahead Triumph 16
T Moving Gas Tank Triumph 5
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
