Help ordering brake lines for Bugeye
ichthos
Hello,
I have decided to order the premade stainless steel brake lines for my 1960 Bugeye. A number of you suggested ordering brake lines from Classic Tube. I am having some problems figuring out which lines to order. I will be ordering the complete brake line kit, but this does not include the wheel cylinder lines. My car is stock, and the front brakes have transfer tubes between the wheel cylinders. Does the rear also have transfer tubes? Thanks,
Kevin
Drew just ordered a set yesterday for Tunebuggy his BE from those folks. I'm sure he can provide guidance. You'll have an answer soon.
I did just order a set a couple days ago. Give them a call, the guy was very knowledgeable and helpful. Tell him what you've got and he'll get you the right part. I wound up getting the set for the 1959 Sprite, and the clutch line. He did mention that the transfer tubes were separate, but as I've got discs on the front they weren't needed.
If I remember correctly, the rears don't have a transfer tube, as they have just a single slave cylinder. You'll need to order the front transfers.
Thanks for the help. Classic Tube did not seem real knowledgeable when I called, but I figured it was my job to know which lines I needed anyway. I am at work, couldn't remember my current set-up, and wanted to get these ordered today. I forgot there was only one cylinder in the back, so that information helped me finish the order. I just ended up buying the basic brake kit and then ordering a pair of the transfer tubes. After I get my brake lines in I can finally get my front susupension back together -Yeh!
Kevin
Heh, guess who gave them all the info so they would have Bugeye lines to sell.
Miss Agatha did it. LOL
Glad you got it worked out -- maybe I just got lucky and got the one guy who knew?
I had mine made locally by Royal Brass and Hose. They did a great job.
J need help ordering paints Triumph 6
jaybird Need help ordering from Moss - ASAP! MG 25
JPSmit Parts ordering help Spridgets 8
F Sprite Gearbox Help Austin Healey 6
Y MGB Overdrive help needed... MG 2
D 1953 Riley 2.5L Help, Oil Filter Location Other British Cars 2
HealeyRick Help with Testing New Wiring Harness without Letting the Smoke Out? Austin Healey 4
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 12
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 3
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
