TR2/3/3A Help! No start! Need input from you guys.
karls59tr
Bronze
:mad-new: No start. Battery and starter crank motor. Have gas to the carbs. Have spark to the plugs. Here's the back story. I was installing new points and condensor. I managed to drop the the hold down plate screw "lock washer" into the distributor so I had to remove the dist and shake out the lock washer. However I was very careful to mark a number of places on the distributor to make sure I put it back in the same place. Did not move the engine. I've checked the grounds at the battery and body. No wires loose at the ignition switch. Anyone have any ideas of how to track down the issue? I'm not at the side of the road or anything but in the garage.
TR6 ignition points 001.jpgSee if you have this..special attention to parts 2, 6 and 7
Rotor cap Carbon brush present? Rotor installed? I have left it off that is why I ask.
Distributor shaft engaged in the drive? Rotor pointing at No1 cylinder plug wire when No1 cylinder is TDC?
David
Would that insulating washer come installed on a new set of points?
If you mean #6, typically yes these days.
But if you have spark I do not think the points installation is likely to be your problem. more likely timing. If you put the engine at TDC for the compression stroke on #1 where is the rotor pointing?
I repeat the age old mantra - if its got gas and its got spark and if they both arrive at about the same time , its got to run. If you assembled the points correctly as Poolboy pointed out (most point sets today come pre-assembled) and have spark at the plugs and gas is getting to the carbs and it ran fine prior to your pulling out the distributor, it must be the distributor in the wrong position.
You are right. The distributor was in the wrong position. I was trying to set the timing by using the the TDC hole in the pulley to no avail. Eventually I spotted a white mark on the pulley that I must have put there years ago. I used that as my TDC mark and now all is well. I should mention that on the new ignition parts that I ordered the capacitor and bush terminal ring ends on the wire leads were so big that they touched the plate hold down screw and the wire connections were flimsy. The points did not look too substantial either These parts came in Lucas boxes but the points did not have the Lucas engraving on them? I ended up using an old base plate for the points and changing the ends out of those lead wire with the ends of the old parts. I was looking at some old ignition parts I had saved that were genuine Lucas parts and they were made way better than the "aftermarket Lucas" parts I ended up with.
I rebuilt a stack of distributors 8 years ago. The old points were well made and sturdy. The new ones are flimsy and never come close to lining up the contacts. It's a real shame the repro parts are as bad as they are.
D 1985 xj6 wont start, need help ASAP,no car :[ Jaguar 2
S Wedge Need Help Badly! - New TR7 Won't Start! Triumph 11
curdy TR2/3/3A TR3 No Start...Again. Help? Triumph 62
G Help!!! No spark, no start Austin Healey 2
E Help! Won't start Austin Healey 17
mountainman TR2/3/3A TR3 No start No spark Help Triumph 10
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
I Bugeye won't start - help please Spridgets 22
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
2wrench HELP! My car won't start. Triumph 65
J help-won't start Spridgets 16
chicken Help needed to start my engine ! Austin Healey 16
vping Car will not re-start after a drive - Help. MG 48
F TR6 Help..TR6 won't start after months of sitting Triumph 33
N MGB My MGB Won't Start--Please Help MG 36
J 95 XJ6 Will not start PLEASE HELP Jaguar 2
P hello and help, my baby won't start MG 17
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
