Thanks Steve. Latest is: removed dizzy, cleaned it out. Replaced the pertronix with a new one. Replaced both the rotor and distributor with new ones. Checked gas line. Getting fuel, battery on full charge. Tried to start and the car, turned over very sluggishly, no backfire. Now getting spark. Rotated the dizzy both directions, no change. With the dizzy off the rotor turns normally and car cranks normally. Thought I had the dizzy in backwards. Turned it round 180 degrees, car turned over as normal but constant backire. Thinking now is, I had the dizzy in right all along. Will turn it round again. Perhaps try your idea of installing points and condenser. After 4 hours, went to bed. Very frustrating.
Regards,
Eric
