Help, I need a knock off wrench
Westfield_XI
Does anyone have a used octagon knock off wrench they can spare to sell to me? I seem to have misplaced mine and am stunned at the price asked by VB and Moss........ FYI, they are asking $49.95. I need to pull my axles to get the diff out and off to a rebuild shop.
jlaird
Would a brass or dead hammer from Sears not work just fine till you can get one on eBay?
Deleted member 8987
This is the octagon bit that fits onto the Fed Safety caps.....you put it on, hold it, and wail away with your BFH.
I know other marques were forced to use those type caps.....anybody in your area with a similar vintage other marque?
BlueMax
If you had some ¼ plate steel and a plasma cutter you could easily make one. Hey, If you don’t have one it would be a good excuse to tell the wife that you needed another tool.
RickB
For $20 shipped? Get the Ebay wrench - no-brainer there!
Some knockoff's have the ears, I think that's what Jack was referring to with his suggestion of a dead blow hammer. Wouldn't work very well on the ones that are the plain octagons.
Westfield_XI
Westfield_XI
Billm said:
Or just change over to eared knockoffs!
BillM
You know, I just might do that....... But I still would need to get the old ones off first. I'll go compare prices of the eared caps vs an octagon tool.
jlaird
If you finished with the octagon bolts use a pipe wrench.
nomad
For eared knock off's I've got a home made hammer that came with a car. It is made up of about 5 lbs of wheel weight lead poured in a tin can around a piece of 3/4 pipe with pipe caps on each end. The can was then removed.
It does'nt damage knock offs and removes any wheels with just a couple of light taps. Can't beat the inertia in all that swinging lead. First knock off hammer I grab around the shop.
Kurt.
Westfield_XI
Westfield_XI
regularman said:
No, use a couple pieces of leather on the jaws and take them off with care and send them to me :smile:
I just looked and the two ears are $109 a set and the octagon tool is $49.95. This is gonna take some thought.......
I am going to see if I can try the padded jaw technique with my 24" Ford wrench, if that works we shall see about replacement.
aeronca65t
Westfield_XI said:
........with my 24" Ford wrench.......
:lol: :lol: :lol:
Billm
That ebay post for the wrench was (and still is) $12.99 as "buy it now"
Why not get that one?
BillM
Westfield_XI
Westfield_XI
Well, the Ford wrench got the L/H side off, but the R/H was resistant. Luckily, just as I was reaching for the pipe wrench, I found the missing tool and used it to remove the other one.
However, all this thinking about knockoffs has convinced me to buy some bling for my car, so I am going to get a set of the 3 ear Boranni type. Thus I will have a set of octagons available with the correct 1967 wrench too!! Contact me offline and we can make arrangements for shipping once I get the new ones mounted.
You have better luck than me. I would have found the tool AFTER using the pipe wrench.
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
