Heater rebuild or replace
Richard Dickinson
While refurbishing the heater in my BT7 I discovered it had a small leak in the core. My options are to try to get a radiator shop to fix it, get a new core for about $220, get a whole new modern heater from Cape International. My experience with domestic cars has been to just get a new core. I don't know if they are really reparable. The Cape International would be about twice as much as a new core, depending on the exchange rate and shipping costs. Is the Cape heater that much better and is it pretty much a bolt on replacement?
You could go to Vintage Air or JC Whitney. Both have heaters and you just need to find a size that is similar. IE: they will more likely be a rectangle shape vs round core.
why would you need a heater in a Healey in Arkansas?
All-tho we don't usually get long periods of cold weather here it often gets down in the teens or lower. When I used the Healey as a daily driver back in the 60's I used a 180 degree thermostat in the winter and sometimes covered part of the radiator with cardboard.
Richard,
I would stay with replacing the original. Patching is only a short time remedy as the corrosion is likely throughout the heater core and will eventually fail again. Staying with the original type will keep the value of the car high also, as installing other types will (vintage air/etc.) cost you if you have to sell.
I hope this helps.
Jerry Rude
BJ8
Europa TCS
You might be surprised how well the heater works after fixing it. This is what they look like inside after 50 years
The control valve corrodes pretty badly too so might be a good time to replace it if you aren't planning to do so already
Andy.
S TR4/4A Replace or rebuild heater control valve? Triumph 5
6 Smith heater rebuild Austin Healey 8
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
J TR2/3/3A TR2 Heater removal and rebuild Triumph 4
luke44 Heater Motor Check and Rebuild Triumph 1
M Heater Case Rebuild Triumph 6
Brosky Heater case rebuild project finished Triumph 15
Bill Redd Heater Box Rebuild Triumph 10
D SII E-Type Heater Box Jaguar 0
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
Y MGB Do I need a heater valve? MG 1
BierRunner TR6 Thank You - Heater control Valve Replaced! Triumph 1
BierRunner TR6 Removing the old Heater Control Valve Triumph 2
HealeyRick Cleaning/Renewing Heater and Fresh Air Tubes Austin Healey 8
BierRunner TR6 Heater Valve Triumph 20
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
