Fuel line size and fittings
rfitts
installed new aftermarket fuel tank in 1961 BT7. The fuel line going through the backwall of the trunk to the tank is too short. I will need to bend up a new fuel line from the pump to the tank. How can I go about specing out the right fuel line and fittings?
Google "Mr Fine Spanner"
I have a rubber hose that connects the fuel tank fitting to the steel fuel line.
There are a few elements of my car that aren't original, the fuel line being one of them...
I used 3/8" stainless steel tubing and associated Parker (or SwageLok) ss compression fittings.
I'm pretty sure that the original run was 5/16" tube, in mild steel with soldered brass fittings.
Hi, Fuel tank outlet, if original, should be 1/4" BSPPT (British Standard Parallel Pipe Thread). It needs a 60 degree cone seating with a nut holding it in place. There are adapters available to use an AN fitting. Pegasus Racing has a pretty good overview (www.pegasusautoracing.com) . Good luck, Bob
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
RJS Fuel Line Size Triumph 2
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
P TR6 Fuel line and Foley catheter blockage Triumph 5
K TR2/3/3A Copper fuel line..... Triumph 6
M TR4/4A Exhaust/ Fuel line? Triumph 8
