PatGalvin
Hi Guys
Well, I've finished block sanding the TR3 - I've been at it since before Thanksgiving - is a huge effort, to say the least. Photos to follow on that.
I need to install a new fuel line before I put the body back on the frame and am doing some planning. I have a replacement tank from Jorge in San Diego that I'll be installing. I have the old fuel line and fittings as a go-by. My car was missing the shut off valve near the fuel pump so I do not have that device.
Two questions - for those that have replaced your fuel line - did you purchase a precut line with appropriate fittings from one of our esteemed suppliers, or did you reuse fittings and just purchase 5/16th tube from FLAPs? Second, what options do I have for replacing the shut off valve up front? I don't need for this car to look original but do think it might make sense to have a shutoff valve at the end of the hard fuel delivery pipe. Has anyone come up with a fuel shutoff modification that has worked well?
Thanks for the tips. Photos of finished sanding and of my garage paint booth to follow in next few weeks.
Pat
Pat
