Front Shocks Bushing Replacement
au672000
Hey guys, Been awhile since i posted. Redoing the front end and upgrading brakes on a 100-6. Having a difficult time replacing the bushings on the upper trunion to the lever shock. What's the easiest way to tackle this? Btw using poly bushings.
Ashley
red57
Back off the pinch bolt in the shock arm a long way and you can spring the arms apart a bit and then drive a large straight bladed screw driver in as a wedge to keep the arms separated a bit and then set the arm over the bushings and insert the bolt. Pull out the screwdriver and tighten the bolts. You should have a 2" spacer under the shock arm before tightening the bolts. Actually, for the poly bushes you don't need to have a spacer in place first but if you still have rubber ones in the lower a-arms, you should still use a spacer. And don't forget to lube the poly bushes or you may have a squeak.
Dave
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
M Replacing front shocks, torque setting? Spridgets 2
B Front Shocks Austin Healey 6
RJS TR4/4A Replacement Front Shocks Triumph 4
D front shocks 100 m Austin Healey 12
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
N Hillman Imp front shocks wanted Other British Cars 2
tomshobby front shocks, about time I think. Triumph 6
J Front shocks Austin Healey 5
PAUL161 T-Series TF Front Shocks-[Backwards]? MG 5
J Replacing front shocks. Austin Healey 3
AUSMHLY Front shocks: guaranteed not to leak ? Austin Healey 6
R Bugeye front shocks Spridgets 3
mrsprite front lever shocks for sale Spridgets 2
BOBBYR BJ8 FRONT SHOCKS Austin Healey 10
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S BJ8 Shocks and Front End Austin Healey 15
19_again front shocks filler location MG 4
Shinsen774 Install Front Lever Shocks-What's the secret? MG 3
F TR2/3/3A TR3A front shocks Triumph 2
bluemiata90 TR6 TR-6 front shocks in a TR3?? Triumph 2
B front shocks MG 33
zimmy changing front lever arm shocks Spridgets 4
Morris New Front Shocks! Spridgets 2
kodanja TR6 TR6 FRONT SHOCKS? Triumph 24
D Front Shocks. Spridgets 19
mrv8q TR2/3/3A TR3 Front shocks Triumph 4
jscott TR2/3/3A TR3A front shocks Triumph 1
M Front shocks MG 8
M Front shocks MG 4
Basil Front shocks installed tonight! Jaguar 12
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
