TR6 Frame repaired?
Ribbs
Just got the body off the old frame and was wondering if those gusset plates, located on the top of the frame near each trailing arm mount, are attempts at a frame repair. I assumed I'd find indication of a repair attempt as the doors had the telltale wider gap at the top.
CJD
I don't know anything about the TR6, but I would like to think the factory would cut gussets closer to shape than that?!?
Popeye
Bronze
Looks like something done after the frame left the factory. Like John, I'm not familiar with a TR6 frame, but an online search of it does not show the gusset plates.
sp53
I was looking at the picture and from a carpenter prospective, I would cut the flat piece out and those existing gussets and then use a large gusset of 16 gauge sheet metal maybe 2 foot by 4 foot to span over the whole area on both sides of center and down the frame enough to gusset to the outsides then weld. It would make it stronger, lay flat, and be hidden by the floor
With plywood on a truss or floor spanning an area with say 16 inch openings, the plywood method is stronger than most stuff. You can make a lot of welds or in carpentry they call it a gang nail. That should work and be cheap and easy to do.
Steve
malbaby
Definitely home made gussets....That frame [what can be seen in the pic] is in poor shape, but fixable.
All IRS frames flex and twist at the cruciform section, notably the frame rails at the rear of the top cruciform plate.
This can be minimised with extra strengthening measures.
Your decision will be to fix what you have or buy a new "Ratco" frame.
Sarastro
Home-made and not well thought out. Some extra gussets, as well as vertical strengthening of the rear pieces, is a good idea, but that's not the way to do it.
In the TR4A, it's customary to strengthen the differential mounts and front suspension mounts; you can do a little on-line searching to get the details. Some of this has been done in the factory TR6s, but maybe not all.
Madflyer
not standard fix I built my 1973 TR6 from three cars and had to start with the best frame of the three. Seeing the factory work and weak points I did the following. one Added a plate to the diff, studs and welded the studs at the top cross member they are known to pull out. two the cross member I added a angle across the back as one frame had broken there and spring pocket was bent badly. three I added a plate to the back side of the pivot the swing arms through bolt to as they will bend because of the two bolt holes. Several of the frames had broken there maybe due to hitting pot holes. I also cleaned all factory weld and added as needed. The frame must have been built on Friday late and the welded did not complete all welds.
I am not sure where the frame spent it life as to all the rust TR's leak as to protect from rusty frames. TR's are known to mark their parking spot.
When you get to the front caution when removing front A arms as not to strip bolts. And last the Bently book gives all measurements to true frame and will make fitting door much simpler.
S New vs. Repaired Frame Austin Healey 28
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
C TR2/3/3A Frame repair and value Triumph 2
zoohow BN4 Top Frame Installation Austin Healey 1
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
S TR2/3/3A Placing the differential on the frame Triumph 4
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
S TR2/3/3A Frame repair. Triumph 47
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
ActionJackson Spitfire Frame Triumph 0
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
7 Wedge Removing sunroof frame Triumph 5
Rut TR4/4A 4a frame modification Triumph 6
D General TR Frame repair - recommendations for NJ area Triumph 3
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
D TR2/3/3A Windshield frame fitting. Triumph 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
JamesD BJ8 Top Frame Bumpers Austin Healey 12
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
Healey Nut Seat Base Frame Position Austin Healey 4
P TR6 TR6 Frame Stiffener Triumph 4
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
C 100/6 BN4 Soft Top Frame Austin Healey 16
B Bent frame rails near BE front end Spridgets 2
F TR2/3/3A Bumper frame brackets Triumph 10
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
F TR2/3/3A Bumper bracket to frame question Triumph 7
P For Sale MG TF Ash Frame parts for sale MG Classifieds 0
D BJ7 Hood frame mounting plate Austin Healey 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
dbenichou289 TR2/3/3A top frame bracket Triumph 7
J Painting a Frame and Substructure Austin Healey 12
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
P BJ8 Frame Rust Options? Austin Healey 14
Rut TR6 TR6 frame Triumph 3
Got_All_4 TR6 Starting my frame restoration Triumph 32
M BJ8 Frame Dimensions Austin Healey 2
