TR6 TR6 Frame Stiffener
pdplot
Local TR6 owner was parked in lot when a guy came up and acting like a real expert said "Of course, you stiffened your frame"...
and went on to describe how he should have placed gussets or stiffeners at the midpoint of the frame to prevent sagging and problems with door shut lines. Anyone ever do this? Admittedly, the TR6 frame is not that robust as jacking it up from both ends will quickly prove, but is it really necessary to do this?
charlie74
Sounds like a bit of a blow-hard…
A TR6 frame isn’t terribly strong and most owners know that jacking one up with the doors open/removed can result in damage. My car is on its original frame which has required repairs (trailing arms and usual trouble spots) but no special modifications to stay true. Seems like noise to me…
mctriumph
This if horse apples.(Mash reference). While it is too flexible it is not easy to "fix". My hindsight suggestion
to the factory(1960) when they went to the Tr4 would have been to stiffened up the sill/rocker assembly.
These ,when securely bolted to the frame out-riggers(likewise stiffened) would have gone a long way to
a stiffer platform.
Still working on the time machine(based on a Tr3 cause it makes me 18 again!)
MD(Mad dog)
M_Pied_Lourd
I think the only absolute necessary modification to be done are the boxing of the differential mounts and the addition of the extra gusset on the lower control arm pick up points on the early frames. Some other modifications to the frame can help but are not “essential”.
Cheers,
Tush
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
Rut TR6 TR6 frame Triumph 3
Got_All_4 TR6 Need a frame for TR6 Triumph 21
D Wanted TR6 Frame Triumph Classifieds 0
D Wanted TR6 Frame for '74 Triumph Classifieds 0
B Wanted Late TR6 Gearbox frame Crossmember Triumph Classifieds 1
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
cmacmillan TR6 TR6 grille frame Triumph 2
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
R TR6 Frame part tr6 Triumph 9
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
Scot1966 TR6 TR6 Frame Triumph 20
Scot1966 TR6 Tr6 Frame repair Triumph 0
G TR6 TR6 dash and windshield frame removal Triumph 13
M TR6 TR6 frame off restro Latest [pics] Triumph 6
M TR6 TR4A on a TR6 Frame? Triumph 19
T TR6 What to do with '71 TR6 body/frame Triumph 27
TulsaFred TR6 TR6 purchase...Frame rust Triumph 17
S TR6 Replacing my tr6 frame. Any sugestions and body Triumph 5
B TR6 TR6 frame Triumph 5
B TR6 TR6 body to frame location Triumph 3
B TR6 I have to buy a used frame and tub for a TR6..... Triumph 14
I TR6 TR6 windshield frame bent? Triumph 8
K TR6 T4A IRS chassis frame same as the TR6? Triumph 4
charlie74 TR6 tr6 frame dimensions Triumph 7
R TR6 Tr6 Winshield Frame Restoration Triumph 7
I TR6 TR6 convertible frame top help Triumph 1
D TR6 TR6-windshield frame to bady sealer Triumph 3
Tom74TR6 TR6 74 TR6 Frame - free to a good home Triumph 0
tr6web TR6 TR6 Frame repair progress - it's done! Triumph 10
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
T TR6 TR6 rear frame repair Triumph 2
Tosh TR6 "Sub" frame connectors for TR6? Triumph 8
C TR6 TR6, TR250/5 Frame Dimensions...Who has them? Triumph 3
Brosky TR6 TR6 Front License Frame - a possible market? Triumph 30
Brosky TR6 Anyone need a TR6 frame all ready to go??? Triumph 12
Airfix TR6 TR6 frame differences? Triumph 7
G TR6 TR6 Frame Triumph 4
tr6web TR6 TR6 Convertible frame repair Triumph 2
C TR6 TR6 Frame and Body repair Triumph 2
tr6web TR6 Body and frame repairs TR6 Triumph 0
Y TR6 '75 TR6 frame height? Triumph 1
M TR6 Windshield Frame Color, TR6 Triumph 7
Bill Redd TR6 Frame color - TR6 Triumph 7
