TR6 TR6 top frame windshield seal.
TR3TR6
Is the best way to slide the top windshield seal in that little track is by using liquid soap, or does something else work better?
spray on silicone works well as well. I presume you mean the three piece seal on the leading edge of the top frame the seals to the top of the windshield frame?
Thanks guys, I may try the poke method first, that way I don't have to try and slide the seal thru all three pieces.
I had a commercial window installer put in a rear window of the surrey top. He used a spray can of foaming window cleaner. I continued to use it when I have done additional windshields. I used it up on the last one or I would give you the name. Big advantage is no residue to clean up, just use a bit more to clean up the glass.
Charley
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
I TR6 TR6 convertible frame top help Triumph 1
EWD TR6 TR6 top dash trim paint Triumph 2
W TR6 Tr6 soft top lnstall Triumph 5
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
D TR6 76 TR6 Soft Top Triumph 2
k60djg TR6 TR6 Hard Top Fitting Instructions Triumph 5
C TR6 Truly Top-Flight TR6 V8 Triumph 1
cmacmillan TR6 TR6 Top rubber window seals Triumph 13
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
W TR6 how to lowering 1972 TR6 soft top Triumph 4
G TR6 Spotted TR6 Hard top for sale Triumph 0
ScottTR6 TR6 Advice for new TR6 Soft Top Triumph 9
K TR6 TR250/4 top on a TR6? Triumph 11
I TR6 TR6 hard top advice please Triumph 3
bcbennett TR6 TR6 top cover/plastic snaps Triumph 5
wangdango TR6 TR6 convertible top "tab"??? Triumph 1
wangdango TR6 TR6 convertible top woes..... Triumph 3
eschneider TR6 what is TR6 hard top worth? Triumph 7
G TR6 TR6 Top Triumph 6
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
eschneider TR6 What does this top boot / cover fit? TR6? Triumph 4
MadRiver TR6 Rubber seal on top of grill on TR6 Triumph 5
B TR6 71 TR6 Covertible top hardware Triumph 7
B TR6 TR6 Convertible top Triumph 16
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
C TR6 TR6 Top Speed? Triumph 42
prb51 TR6 Top Gear TR6 moment Triumph 9
R TR6 Ebay TR6 Hard top Triumph 10
jjbunn TR6 Hot news: TR6 on Top Gear Triumph 12
T TR6 tr6 top seals Triumph 8
T TR6 tr6 top seals Triumph 2
cutlass29 TR6 TR6 convertible top cover...help! Triumph 4
2wrench TR6 Looking for tips on folding soft top TR6 Triumph 11
delisaj TR6 TR6 Replacement Convertible Top Triumph 23
tomshobby TR6 Free TR6 top Triumph 11
YankeeTR TR6 top gear TR6 video....required viewing Triumph 7
M TR6 TR6 Hard Top Seals Triumph 0
V TR6 TR6 Hard Top Triumph 13
I TR6 Best place to buy rag top for TR6? Triumph 4
trrdster2000 TR6 TR6 top question Triumph 7
TR674 TR6 TR6 Soft top Triumph 6
H TR6 Spring Washers for Soft top latches TR6 Triumph 3
