For Sale Four Steel Wheels Triumph TR3 or TR4
FloridaMGA
Hello, my MGA came with four steel wheels that are not correct for the car. I did some research and these are original steel wheels for a Triumph TR3 or TR4. I sourced some MGA wheels so I have no use for these wheels. Located in Tampa, FL if anyone has an interest. $150. Thanks! Jeff
Jeff, check your "private messages" (conversations).
Hi, Do you still have the MGA wheels for sale? These appear to be the correct MGA 1500 wheels. If so are they straight with no bends or kinks? I have a 52' MG TD with mgb gt front disc brake conversion. I have MGA 1600 wheels, very similar but a little different. They have some outer rim kinks so I'd like to replace them. Jim G, Babylon NY
Yes Jim, I still have the wheels, but they are not MGA wheels. They came on an MGA I bought but I found out they were not the correct wheels. There are similarities and they surely would bolt up, but the size of the holes and areas around the wheel cover posts are a little different. Here is some info on the MGA stock wheels. > Wheel tech - MGA wheel types < Jeff
CARSINC For Sale Four Octagonal Knockoffs Spridgets Classified 0
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
JPSmit Question four - headlight trim ring Spridgets 9
T Morgan Plus Four Presssure Plate Other British Cars 1
J Can A BJ7 Two Light Schroud Be Coverted To A Four Light BJ8 Style? Austin Healey 6
5 Looking for four original sprite rims Spridgets 10
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
tinman58 back on all four Triumph 1
D Bn1 four speed? Austin Healey 2
aeronca65t Four Wide finish. Racing 3
aeronca65t Four Lotus Cars Lotus 6
PC four wings Spotted 1
Sarastro Four RWA Midgets on LA-Area Craigslists Spridgets 4
J TR4/4A TR4A - Four letter word Triumph 20
B TR2/3/3A 1957 TR3/ Minor detail questions Part FOUR Triumph 6
regularman LA Seven Mary Three and Four Spridgets 1
Morris Tube shocks on all four corners! Spridgets 13
drooartz Four years ago today... Spridgets 7
T Drew - the Bugeye is back on four wheels Spridgets 14
R Holly cow there were four!! TVR 3
Trevor Jessie Small four post lift Spridgets 9
drooartz Progress: four wheels on again! Spridgets 6
rick_ingram Four Link install complete MG 0
rick_ingram Classic Conversions Four Link Rear Susp Installed MG 2
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
rick_ingram Classic Conversions Four Link MG 4
JPSmit one step forward four @#$%* steps back Spridgets 16
A Austin Ten Four Chrom Rad Wiring Other British Cars 13
2wrench Head gasket with four holes Triumph 3
jmwuva05 I need a four way brake union bad!!! Spridgets 4
Bruce_B New oil pump with 2 screws - old one had FOUR!!? Spridgets 3
C Toyots Four Pot Brakes Pictures Triumph 12
D Wedge TR7 four cylinder Triumph 2
jlaird Only four more members Spridgets 13
Team_Sprite He stood on his own four feet tonight! Spridgets 2
aeronca65t Ariel Square Four British Motorbikes 10
DrEntropy It only took me four years! Other Cars 23
T TR2/3/3A Four inch wider TR3 photos available! Triumph 17
D Steel wheels for XKE Jaguar 5
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
