TR6 Follow-up to hard starting
pdplot
garage temperature 45F. Car sat for 6 days. Started in 6 seconds. Much better but acid test will come letting sit for 3 weeks or more. Raining outside so I didn't take it out nor did I let the engine warm up at all so as not to make condensation in the oil.
Might take a little longer because the fuel in the float chamber is going to be a little lower.
But that's not a bad thing in my opinion, the additional cranking time will get the oil circulating, especially to the rocker assembly which is always a little slow getting oil at start up...at least if the engine hasn't run in a while.
PD, Just a BTW:
thanks to your "hard starting" thread, I am no longer wearing out the gas pedal trying to start my 3A, under full choke.
just bump it a few times & she fires right up.
always nice to learn something new.
thx again.
Guy
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
jlaird MGB Follow up to my bad post on prewar MGs MG 4
longbridgehealey Horn question follow up Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
drooartz The teardown begins, follow along at home! Spridgets 51
D TR6 Follow-up question Triumph 3
P Follow up to valve job Triumph 3
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
KVH TR4/4A TR4A OD Follow Up Triumph 10
tahoe healey Gunson colortune follow-up Austin Healey 17
nevets intermittant sputtering follow-up Austin Healey 13
eschneider TR2/3/3A follow up - TR3 broken pushrod &compression test Triumph 1
G follow up question on ZDDP Triumph 12
tahoe healey dizzy follow up Austin Healey 7
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
G Follow-Up Horn Question Triumph 2
T Wedge Follow-on TR8 interior question - seats Triumph 4
N TR6 Follow up on lean TR6 carbs Triumph 1
J Failed State inspection-tie rod end..follow up Spridgets 4
C Follow up on Datsun 5 Speed Spridgets 11
RickB MGB-GT Follow up ?... Exhaust on the MGBGT all good MG 9
X Schumacher follow up. MG 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
jlaird Want to follow along Spridgets 11
B TR6 Follow-on question regarding new TR6 tires... Triumph 5
B Darn Things Follow Me Home. Spridgets 14
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
nevets OD follow-up Austin Healey 0
jlaird Follow on question, Differintal Spridgets 3
S atmospheric crankcase follow up Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
