    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Exterior paint - rusty spot
NutmegCT
Here's what I want to repair - somehow an area on the front fender of the Benz lost its paint and the steel is rusted. Area is about 3" x 3"
Other than this area, the other paint problems are tiny surface nicks, no rust.
My plan: clean the big area with paint thinner to remove any wax, water wash and dry, sand to bare metal, prime, paint (NAPA matched-color aerosol single coat). Original paint is Daimler-Benz "synthetic resin varnish". After a few months, I'll rub down and buff the entire car.
Does the plan make sense? Any other suggestion?
Thanks.
Tom
Short of repainting the whole fender, your plan sounds feasible. With an off-the-shelf rattle can you'll not get a very good color match on aged paint though. My local paint vendor will match existing paint and make a custom rattle can of it. I suspect yours will too. At least with that you should get a reasonable color match. Be sure to bring the sanded spot up with a good primer before shooting the color or the low spot will stand out like the proverbial sore thumb.
Thanks very much. Never did this before.
My local NAPA will color match; give them a sample piece and they scan it. So I'm not planning to use an off the shelf can.
Question: I've worried about that "low spot" issue a lot. How the heck do you get the primer to fill in the low spot, without also raising the area around the spot? With the rough ragged edges of the spots, you can't exactly mask it.
Thanks.
Tom
Masking would leave an edge. You have to feather the paint around the spot. Then shoot the primer extending a little beyond the feather. Finally sand it back down using a long board. As you start to see the original paint through the sanded primer, you will have raised the low spot a little as it did not get sanded. It will probably take more than one coat. Those old Benzes had pretty thick paint. Eventually you will eliminate the low spot. On second thought, I think I would shoot one or two coats of primer as stated then do the rest of the build with the final color. Kinda depends on how much build is needed. You probably can safely build more with the primer than the topcoat.
P Matching Carnival Red Exterior Paint Sunbeam (Rootes) 2
NutmegCT Exterior wood finish Restoration & Tools 21
Michael Oritt Exterior cover recommendations Austin Healey 7
S LED Exterior Light Upgrade Spridgets 15
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
johnrip Wedge TR7 exterior door handle buffer instalation Triumph 3
K Cleaning up exterior surface of SU's? Triumph 8
S TR2/3/3A TR3 Exterior Door handles Triumph 4
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
S Interior/Exterior color choices........help? Jaguar 12
N Exterior and Interior color codes MG 3
angelfj1 TR2/3/3A TR-3A exterior lighting - best source Triumph 4
NutmegCT fuzzy red exterior! Triumph 3
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
S Bugeye exterior colors Spridgets 4
M TR2/3/3A TR3 photo - exterior [2nd try] Triumph 3
M TR2/3/3A TR3 photo - exterior Triumph 0
W Exterior Heat Insulation?? Austin Healey 20
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
