Dive Shaft Uni Joints
zblu
Not long after I had new uni joints installed to the drive shaft someone in passing said there were better types available, I assume they are a common item to all Healeys, so are there any recommended types/ brands?
Keoke
Hi I would not worry about it too much because if the parts you have installed are not up to the task they will let you know. Further, Uni part is not a single source supplier and the parts you have may be among those in the Irish whispers you heard.---Keoke
Z
zblu
Keoke,
You talk in riddles, do you mean I have irish parts installed by leprechauns? :smile:
and uni is wrong and it should be multi? or should I get my next cup of turkish coffee grinds read? :smile:
I am curious as to whether regreaseable or sealed for life are the way to go, One supplier mentioned is Hardy Spicer,
Guess I best check to see if they are in phase first
Dougal
Zblu,
I can't comment on the little green people. However I did spend a morning the other week replacing the UJ's on my car. The old ones had nipples the new ones have not. Supplied by Geoff at the Healey Factory.
It was disappointing as it turned out that I did not need to do it(could have left it for another 30K). I had a "Clonk" when going from forward to reverse and assumed it was the driveshaft.
When I eventually got round to removing the drive shaft I found it was not to bad. The "clonk" was coming from my diff.
Thought about doing it myself but got it done by Upper Classics here in Christchurch. I replaced all bearings and a few shims and now its good as new.
Since I had the parts thought I may as well fit them.
Dougal
Z
zblu
Dougal,
From what I've come across the uni joints should be fitted at 90 degrees to each other also so as to minimise amplitudinal effects, you still have to balance all
Z
zblu
Dougal,
Had a similar clonk, after pulling the diff etc, turned out to be a hub extension that was worn, but had pased a visual re replacement during the refurb
Keoke
Keoke said:
Hi I would not worry about it too much because if the parts you have installed are not up to the task they will let you know. Further, Uni part is not a single source supplier and the parts you have may NOT be among those in the Irish whispers you heard.---Keoke
Keoke
zblu said:
Keoke,
You talk in riddles, :shocked: do you mean I have irish parts installed by leprechauns? :smile:----PROLLY
and uni is wrong and it should be multi? :nonod: What's in a name! or should I get my next cup of turkish coffee grinds read? :smile:----China!
I am curious as to whether regreaseable or sealed for life are the way to go.
Depends upon ones age. If scuffling around on the floor to grease those nipples is getting difficult by all means get the sealed ones as they will probably out last the greased ones given ones maintenance cycle may be spotty. One supplier mentioned is Hardy Spicer---Good hardware been around for a long time.,
Guess I best check to see if they are in phase first------ If they are not you probably did it! :laugh:
OJ! I just remembered. These after market U Joints with the grease nipples. The nipples are too short and you can not get the grease gun on to them. This requires that you purchase Longer nipples so you can service the Joints. Keoke
Michael Oritt
Hardy-Spicer is known for good quality and is made in AUS (that's Australia, not USA). The following is from the HS website and seems to say that they do or have marketed under the Unidrive name:
<span style="font-style: italic">"In 1983, Hardy Spicer became a division of Repco Universal Joints, and changed its name to Repco Universal Drivelines. Acquired by BTR Engineering in June 1987, we later operated under the name Unidrive Pty Ltd. In 1988, a joint venture was formed by BTR Nylex, GKN Industries (UK) and NTN of Japan, which acquired the entire manufacturing division of Repco Universal Drivelines. Early in 2000 BTR sold its interest to GKN and NTN. In April 2002 Hardy Spicer was purchased by HS Company P/L a 100% Australian owned company."</span>
In any case I use the sealed U-joints that do not have grease nipples--the latter are cross-drilled to provide a path for the grease to reach the bearing surfaces and are a bit weaker. Also the passages are quite small and easily clogged.
As another lister observed, a U-joint will let you know when it is in failure mode and its warning should be headed.
andybj8
zblu said:
Dougal,
my understanding is that the two joints should be in line (mine where when I took them off). Just hand mine balanced.
DNK Anti Dive... Triumph 5
R6MGS Uh oh...Should I Dive?? Triumph 20
K Half-shaft wear? Spridgets 3
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
WHT Rocker Arm Shaft Replacement Austin Healey 21
D XK150 Transmission Input Shaft Jaguar 1
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
Rut MGB 62-67 upper MGB steering shaft MG 3
G Installing New Rocker Shaft Assembly Austin Healey 3
D Spedo shaft direction Spridgets 6
Michael Oritt Propeller Shaft Hardware Austin Healey 6
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
R TR6 Drive shaft orientation Triumph 3
S TR2/3/3A Replacing the cam shaft Triumph 27
W BN1 Gearbox First Motion Shaft Austin Healey 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
P Wanted BN1 can shaft Austin Healey Classifieds 0
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Walter74 Kent AH4 cam shaft Austin Healey 18
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
M MGB First Motion Shaft MG 5
J General TR Cam shaft upgrade????? Triumph 3
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
C TR4/4A Selector shaft seals Triumph 12
R TR2/3/3A Maintenance on Drive Shaft Triumph 18
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
R TR2/3/3A Establishing distributor shaft end float Triumph 4
Simmo MGB Gearbox Selector Shaft Tensioning MG 2
