Looking for some help because I do not understand how the vacuum advance really does.
Anyways, I am making a distributor out of an old box of distributor parts. The hooking up of vacuum advance hook has me concerned that I might break the vacuum advance somehow. I really do not know the difference between a functioning vacuum advance and a broken is , or how fragile they are and just what is side other than they should advance the timing. Maybe it just holds stuff steady. I assume there is some kind of diaphragm that moves out with the vacuum of the engine when it pulls.
Moreover, I do not see how that little diaphragm could pull much inside the distributor because the little knurled not assembly holds the plates kind of tight.
Here are some questions I have if somebody is schooled working on the distributor.
Distributor vacuum advance hook up to the inner plate pin is done how and when?
Should I hook the loop to the pin last or first? Should I roll the distributor inner plate off to side to get some wiggle room or just lift the looped cable up with a small hook and drop it on the pin? one thought it seems to me that a good vacuum advance should have echoing noise like it is hollow to be working, but just a guess.
Thanks Steve
Thanks Steve
