TR2/3/3A Dimmer switch.....any electricians out there?
karls59tr
Bronze
My dimmer switch failed and the new one that is on order may take several weeks to get here. I want to make the best out of what's left of the driving season so I'm wondering what would be the best way to temporarily disconnect the high beams only so I can drive at night without binding anyone?
NutmegCT
Karl - unless I'm missing something, just disconnect the leads going to that dimmer switch. If the leads aren't running through the dimmer switch, the high beams can't light up.
Tom M.
charleyf
Or even easier determine which wires go to the bright lights at the headlights and disconnect those wires near the horns. There are three wires to each headlight. I believe a blue/white, blue/red and black. Of course black is the ground and one of the others is the high beam lights. That is if your dimmer switch is allowing anything to go through. I have had them just stop all electrical flow to the lights. If that were the case then you could go to the dimmer switch wires and make a jumper wire straight through for whichever color wire you wished. And leave the other wire disconnected and covered or protected. You could still have some power going to one of those wires. Better safe than sorry.
Charley
Sarastro
The high/low beam switch turns on EITHER the high or low beams; not both. You could just remove the switch and connect the power-supply wire to the one going to the low beams.
That said, these switches are pretty generic. You might be able to find something locally to replace it.
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
Got_All_4 TR2/3/3A Dimmer Switch Triumph 5
GTP1960 TR2/3/3A Dimmer switch mount [ or learn to leave well enough alone] Triumph 14
J Dash Dimmer Switch Austin Healey 2
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
B Dimmer switch Austin Healey 0
A Dimmer switch relocation? Spridgets 14
S TR2/3/3A tr3 dimmer switch Triumph 8
Newkie T-Series Turn signal headlight dimmer switch question? MG 2
T TR2/3/3A TR3 headlamp dimmer switch Triumph 7
steveg OD switch as Dimmer Austin Healey 4
Newkie T-Series Headlight Dimmer Switch help MG 0
P TR2/3/3A TR3a dimmer switch question Triumph 25
rlandrum Dimmer Switch Mounting Triumph 6
M T-Series Gauge Light Dimmer switch thingy MG 3
F TR6 dimmer Triumph 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
WillR MGB-GT panel dimmer removal? MG 7
H TR4/4A Dimmer control wiring for a 4A Triumph 3
S TR2/3/3A tr3 dimmer Triumph 7
T TR2/3/3A TR3a dimmer Triumph 13
S Head light dimmer swich Triumph 7
19_again turn signal/dimmer on 67 B MG 2
kyreb1862 MGB MGB Panel Light Dimmer MG 32
MrPandy Size of hole in dash for dimmer ? Triumph 6
S Hot rheostat [dimmer?] MG 6
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
R Bugeye ignition switch Spridgets 2
K TR2/3/3A Old school battery shut off switch....... Triumph 3
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
F Wanted Dipping switch cap Triumph Classifieds 1
L What does this column switch do? Spridgets 4
G Brake Light Switch Failure Austin Healey 24
R Wanted Bugeye ignition switch Spridgets Classified 2
B Headlight Dip Switch Austin Healey 4
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
S Overdrive Throttle Switch Austin Healey 4
SherpaPilot TR6 Ignition Switch Question Triumph 13
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
C MGB-GT Reproduction light switch MG 13
timsgolf Center Dash Switch Plate Painting Austin Healey 5
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
P TR2/3/3A ignition switch smoking Triumph 12
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
6 E-Type brake light pressure switch location Jaguar 5
C TR6 Ignition Switch for 1972 TR6 Triumph 1
