TR6 dimmer
ferrdlee
what's the easiest/best way to bypass the non-functioning dimmer so the dash lights are always on when the headlight switch is on?
I just did the very same job yesterday. See here:
If your willing to take the rheostat out, it can be cleaned and function like new.
Typically the grease used in the windings become hard, and does not allow the wiper to make contact.
Once the rheostat is out you will need to pry the tongs open that hold it together. Clean old grease off with alcohol or other solvent. Re-grease and reassemble. Should work like new.
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A Dimmer switch.....any electricians out there? Triumph 5
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
Got_All_4 TR2/3/3A Dimmer Switch Triumph 5
GTP1960 TR2/3/3A Dimmer switch mount [ or learn to leave well enough alone] Triumph 14
J Dash Dimmer Switch Austin Healey 2
WillR MGB-GT panel dimmer removal? MG 7
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
H TR4/4A Dimmer control wiring for a 4A Triumph 3
B Dimmer switch Austin Healey 0
S TR2/3/3A tr3 dimmer Triumph 7
A Dimmer switch relocation? Spridgets 14
S TR2/3/3A tr3 dimmer switch Triumph 8
T TR2/3/3A TR3a dimmer Triumph 13
Newkie T-Series Turn signal headlight dimmer switch question? MG 2
T TR2/3/3A TR3 headlamp dimmer switch Triumph 7
steveg OD switch as Dimmer Austin Healey 4
Newkie T-Series Headlight Dimmer Switch help MG 0
S Head light dimmer swich Triumph 7
19_again turn signal/dimmer on 67 B MG 2
P TR2/3/3A TR3a dimmer switch question Triumph 25
rlandrum Dimmer Switch Mounting Triumph 6
M T-Series Gauge Light Dimmer switch thingy MG 3
kyreb1862 MGB MGB Panel Light Dimmer MG 32
MrPandy Size of hole in dash for dimmer ? Triumph 6
S Hot rheostat [dimmer?] MG 6
