Datsun 5 speed Quick shift/short shift prototype
Gerard
Pictured below is the proof of concept short-shift prototype I developed for the Datsun 5 speed conversion. Yesterday, the final CNC product was shipped to me for final approval and testing, which I hope to have by the weekend.
Besides reducing shifter travel by about 50%, as a bonus feature, it will also fit neatly under the original metal shift turret most people desire to keep in place, as well as use of the original rubber shift gaiter. This is a custom shifter and will include the necessary mounting hardware, new bushings and pivot pin. The shift lever will be threaded to accommodate existing shift knobs, but I can also supply new MG, AH Sprite, 5 speed pattern shift knobs. I am also considering making a "Winged g" badged version that some have requested like seen that on my adapter plates. Installation can be performed with the gearbox already installed.
85% of my intended first run is already pre-sold, but I still have a little time to increase production if others are interested. Please contact me directly for more details if you are interest in having one.
Gerard, is that shifter lever chromed?
Gerard
Gerard
The final finish has not been determined. Chrome is potentially too expensive, but still being considered.
If you are referring to the one pictured, that is just a rough, proof of concept prototype I made from aluminum to test how it world work, feel and fit. A lot of subtle adjustments were needed to determine various factors before turning it over to the machinists. The finished shifter itself will be steel.
JPSmit
Impressive work! great project. I can't use it but, well done and thanks for continuing to care for these little cars!
Gerard
Gerard
Thank you, JP, Much appreciated ... :cheers:
What about cobalt nickel plating?
Gerard
Gerard
That seems like sorting to consider. I'll ask the shop if they have someone who can do that. One option they suggested was a black oxide finish (matte black). There are some very cool powercoat options test days as well. I just dis some furniture pieces in a color shifting bronze metal flake. I saw some spoked wheels done with this color and it can appear black in low light, dark bronze in average light with green and amber highlights.
drooartz
Chrome or chrome colored is what I want -- my goal is for things to look pretty stock, even with all the mods underneath.
That is why I asked about the cobalt nickel. When applied to a smooth metal surface it looks almost like chrome.
Gerard
Gerard
I was only showing those powder coated sample to show how much powdercoating has advanced as far as color and finish options. I'm going to see if I can find someone that does the cobalt nickel plating Trevor suggested, and also the cost. If I can't get that done, I'll likely go with a chrome finish powder coat. The guy I use here does really high quality work.
drooartz
Sounds good to me. Good to have options -- but the pricing on these small batches is always an issue.
Didn't actually realize you could do chrome powder coating
Gerard
Gerard
Yes indeed, this small quantity production is an issue at every turn.
Not only typical chrome look, but also colored chrome, including black.
Gerard
Gerard
Here's the quality finish I can get with ceramic coating. They actually polish it after being baked on at 650 degrees. If I do powercoat (same shop) I suppose I can do custom colors per individual order if someone wants black or some other color.
Jim_Gruber
How about powder coated chrome for windshield frames and cockpit trim?
Gerard
Gerard
Hi Jim,
Not sure what the question is. For aluminum, clear anodizing is a better solution, but ceramic coating was recommended for better durability for something that would get that much handling.
Jim_Gruber
Was just wondering about polished powder coat for cockpit trip. To keep it shiny without maintenance. So clear anodizing is the way to go vs. powder coating like David S. is recommending. If I could get powdercoated chrome not sure why I would powdercoat trim as dull aluminum color. Just thinking out loud. I'd vote powdercoat Gloss Black or Chrome.
Gerard
Gerard
Received the prototype shifter as well as a proposed custom shift knob (not included with the kit) I've shown it with several shift knob variations, including an period original.
I couldn't be more pleased.
https://gerardsgarage.com/Garage/Tech/5speedKit.htm
Gerard
Gerard
I got a chance to install and test drive a Bugeye with the prototype today. The results are even better than I expected. The volunteer who brought his car over said the shifting actually felt better and more positive than with the original shift lever. I only had some brief seat-time, but when comparing the two, it felt that way to me as well. Shifting is crisp and positive.
Gerard
Gerard
The decision has been made to make the shifter from stainless, rather than plating.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
shadowfever Datsun 5-speed info neede Spridgets 5
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
Rut Datsun 5 speed Spridgets 24
T Shifter Cupola for Datsun 5 speed Spridgets 19
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
T datsun 5 speed locking up - circlip problems?? Spridgets 0
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
T Datsun 5 speed locked up Spridgets 7
RickB 65 Midget on craiglist Seattle - 'comes with datsun 5 speed' [nfi] Spridgets 12
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
AN5Sprite Another Datsun 5 speed for sale! Spridgets 8
RickB Fresh Datsun 5 speed and assiciated goodies Spridgets 15
J Datsun 5 speed swap clutch issues Austin Healey 3
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
RickB Datsun 5 speed on Seattle craigslist Spridgets 0
B Datsun 210 5-speed [NFI] Spridgets 5
Rut Datsun yoke for 5 speed Spridgets 26
B Datsun 210 5-speed [NFI] Spridgets 0
PAUL161 Datsun 5 speed transmission MG 10
B Datsun 5-speed trans for sale in Los Angeles Spridgets 4
64rocksprite Datsun 5 speed bronze shifter bushings Spridgets 3
RickB Datsun 210 motor and 5 speed Spridgets 6
jhorton3 Rebuild 5-Speed Datsun Transmission Spridgets 19
B How to identify a Datsun 210 5-speed transmission Spridgets 1
RickB Datsun A14 and Dogleg 5 speed Spridgets 4
Pythias Clutch Throw? Datsun 5 speed. Spridgets 9
RickB Datsun with 5 speed on CL - north of Seattle Spridgets 24
T Datsun 5 speed woes....................help Spridgets 19
Rut Datsun 5 speed Spridgets 4
Pythias Royal Purple in a Datsun 5 speed. Spridgets 6
apbos Speedwell/5 speed datsun/71 mg midget $650 Spridgets 7
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
Gerard Datsun 5 speed part needed Other British Cars 0
Gerard Datsun 5 speed part needed Spridgets 1
L What does it cost to ship a Datsun 5-Speed? Spridgets 7
bill_powell High Torque Starter & Datsun 5-Speed Spridgets 3
G Datsun 210 5 speed disassembly Spridgets 23
AngliaGT 5 Speed Datsun Transmission Spridgets 8
v8mgbal datsun 5 speed Spridgets 30
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
