Thanks Allan and everone!
Allan, your suggestion to position the shutter 1/3 from the bottom may have been the cure. Car started right up and ran like a champ. Seems to pull better, esp. at high rpms, the way it should what with triple carbs, cam, etc.
About the ballast resistor. Car is running fine. I drove it for about 15 minutes and the coil was hot to the touch, but not enough to burn me. Could be from the engine heat as well. Does that mean I'm good with the sport coil, or do I still need a normal coil? Also, could I have a ballast resistor and not know it? And, the really dumb question, where do I get one? NAPA, etc?
Thanks again!
Zach
