RJS
Earlier this morning I posted about dark clutch fluid. That got me investigating my slave cylinder. My research turned up that 1" bore is original to TR4A slave cylinder but, that 7/8" were all that were available for many years. Since my clutch pedal has always been very heavy, I began to wonder if I had a 7/8" and not a 1" bore.
The side of the slave cylinder is stamped "Girling 64670739". But, an internet search for that turns up zero, nothing, nade. Sooo, I went back into the garage, pulled the rubber end cap off and measured the internal bore using calipers. I came up with not 1", not 7/8" but, 13/16". Ugh!
For $35 I am tempted to simply order a new 1" bore slave cylinder, install it and hope it solves my heavy clutch. Going up 3/16" in bore size is nearly 20% which I have to believe will have a significant impact/reduction on pedal effort.
Appreciate your thoughts on slave bore sizes and/or Girling part numbers.
Bob
Bob
