TR2/3/3A How much travel at the clutch slave?
Lukens
I'm beginning to suspect I've sheared my fork pin. I've got a little more than 1/2", but the clutch isn't fully releasing. Comments?
Russ
TR3driver
Great Pumpkin - R.I.P
1/2" should be enough. When you push the lever as far to the rear as it will go by hand (with the return spring disconnected), does it still angle slightly towards the slave? Can you get the recommended freeplay adjustment with the piston fully bottomed in the slave?
When mine was broken, I found that pumping the pedal a couple of times would get the clutch to release.
Geo Hahn
You say it isn't fully releasing -- are you getting some release? Or is the clutch still fully engaged even with the pedal depressed?
I ask because (especially in Florida this time of year) there is another possibility - more likely if the car has been sitting for a week or two.
Lukens
Lukens
Randall, Yes, and yes. Sometimes a few pumps seem to help. Maybe getting that last fraction of travel?
George, I think your asking is the clutch stuck to the flywheel? Don't think so, I drive the car daily. I'm able to shift though the upper gears... a little notchy though. When I pull up to a complete stop I can get into neutral, but when I try to select 1st gear, the clutch is still engaged. If I feel it into 2nd, I can then "crash it" into 1st. Not a pleasant thing.
Looks like I'll be pulling the tranny?
Russ
TR3driver
If the lever is still angled forward, and you can get the proper adjustment, then most likely the problem is not a broken taper pin, IMO. Might be worth rebuilding the clutch MC, just on the off chance it has a problem like the return spring is broken. Mine was broken in 4 pieces when I finally noticed the issue :smile:
I don't know what else it might be, unless perhaps the alignment pins got left out, or the clutch plate is coming apart. Could be a bum pressure plate I guess, but I've never seen one fail like that.
Lukens
Lukens
I guess it could be the MC. I found the spring washer was broken (juice was going back into the reservoir) and put a new kit in it a month ago. I'd like to come up with some way to verify that the slave is getting a full shot from the MC.
Don Elliott
Is the threaded screw holding the yoke at the top front end of the clutch master cylinder rod worn ? I was at the TR races in Virginia way back and that cross-pin was more than half worn through. Also the hole in the yoke had worn. I had spares with me and fixed it in about an hour.
What led me to the solution was that as I pushed down on the clutch pedal, it would move forward but then I would sometimes hear a loud "CLICK". It was the worn cross-pin clicking down into the groove that had occurred.
Don Elliott
What's the latest report on those repro master cylinders that was exposed a few years ago by Frank Angelini ? Those repro units were cr*p. I seem to remember it all had to do with the internal spring assembly inside the master cylinder.
M_Pied_Lourd
Well, the good thing is that you found something. It would have been a shame to get that far and still be scratching your head.
Cheers
Tush
Geo Hahn
I assume you're hip to the use of a grade 8 bolt cross ways to add a second source of fixing the fork to the shaft?
G How much clutch travel? Spridgets 5
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
drooartz How much fender beading for Bugeye? Spridgets 17
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
rkep01 How much do you think this will sell for? Spridgets 33
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
CZ_Dave One is too much, a hundred isn't enough MG 4
R Getting Much Closer Triumph 73
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
F Am i Worrying to much??? Spridgets 9
V How much extra engine oil with oil cooler??? Spridgets 5
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
