Clutch master cyl. push rod
Can a brake master cylinder push rod be used in place of the clutch push rod. The brake one is can be adjusted while the clutch one is fixed. If adjustable, I can take out the little bit of play. Why weren't they made that way? I have extras from replacing both MC's.
TH
I think the adjustment isn't there to take out play, but rather to adjust the relative position of the brake to the gas, which is important when downshifting, to help heel/toe- hence, no adjustment "needed" on the clutch, but I it would have been nice.
B Brake/Clutch Master Cyl. Spridgets 8
P removing clutch master cyl. impossible? Spridgets 4
R T-Series 74 B clutch master cyl MG 7
kbash T-Series Master Clutch Cyl. Rebuild Kit MG 3
B TR6 tr6 clutch master cyl Triumph 4
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch Master Cylinders? Triumph 1
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
N TR4/4A clutch master TR4A Triumph 6
sparkydave 1500 clutch master Spridgets 4
drooartz MGB Difference in clutch master cylinders? MG 4
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
RickB New clutch master - the expected bleeding nightmare has arrived Spridgets 16
RickB Should I rebuild or replace - clutch master? Spridgets 4
Lukens More clutch / brake master cylinder questions. Triumph 7
Lukens Clutch master problems Triumph 23
Jim_Gruber Clutch Master Rebuilds Spridgets 10
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
sail TR4/4A 4A Pipe from Clutch Master to Hose Triumph 4
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
C TR4/4A missing TR4a Clutch master fitting Triumph 9
