Clubman turn signals
King_of_England
Hi....
I have looked everywhere for a pair of decent front indicator and side lamps for a '72 clubman.. Anyone have any suggestions?
Gary
JC_T_ONE
Member
Hi Gary,
I have a VERY good setup, I would rate them good + / very good.
they are complete, and NO corrosion at all, in the fragile alloy housing.
They have original wires, with their Bullet connectors, on all 4.
Non, of the 8 pegs are broken, and all screws for the lense is OK.
the only thing there is to say, is that the original foam seals are a bit dry,
but all there(you can get good repro ones)
I have also shined up the crome, on the lense frame, in a few places, with crome tape,
so they look good.
They are genuine Lucas, if you are interested, send me a PM, with your mail, so I can send you some close up pictures.
You can see them, on my Black WP.
Jens Christian
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
SwamperCa Clubman British Motor Corp 12
G mini cooper v. cooper clubman British Motor Corp 3
A New Mini Clubman British Motor Corp 31
aeronca65t What's a Mallock Clubman? Lotus 12
X Mini Clubman British Motor Corp 2
78Z Mini Clubman British Motor Corp 11
Carlbanan56 MGB Mgb turn signals MG 17
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
bighealeysource Turn Signals Austin Healey 21
B General MG Turn Signal Issue MG 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
G Engine Will Not Turn Off Austin Healey 10
M Europa turn signal problem Lotus 7
Rob Glasgow Turn Indicator Austin Healey 17
doakley Spitfire Turn Signals Triumph 3
R Spitfire Turn signal wiring Spitfire Triumph 5
J T-Series Won’t turn over MG 23
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
T TR2/3/3A turn indicator bulbs Triumph 26
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
E MGB Turn signals 65 mgb MG 4
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
steveg Picture needed - front turn light Austin Healey 4
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
nichola TR6 GP3 Camshaft won't turn Triumph 8
M TR6 Turn signal switch stalk Triumph 1
W MGB Turn signals on 78 MGB MG 3
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
