TR2/3/3A Center main cap engine
charleyf
While starting to tear down an old engine to use in my TR project, I was surprised to find the center main cap missing. So my question is--can I use a center main cap from another engine? This is a TR3 block TS50000, is this main cap interchangeable with a TR4 or TR4A or even another early TR 3 engine?
Charley
What Andy said. The caps were nominally the same for all TR2-4, but each was machined as a unit with the block it goes with. Given the cost of line-boring, it might be preferable to pick up another block that has all it's bearing caps.
You may get away with using plastigage in multiple locations especially were the two halves come together, and top and bottom on both sides of the bearing when installed. Do not turn the crank. Remove the cap and take measurements to see if they are all the same. You can keep the gage in place with a small dab of grease.
Thanks to all. That was what I was concerned about. I'll now switch to a different block. Hopefully nobody has molested the internals on that one.
Charley
timsgolf Center Dash Switch Plate Painting Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
D 62 center shift gearbox Austin Healey 11
R Center Gearbox Input shaft bearing Austin Healey 9
D 1962 center shift gearbox cover Austin Healey 7
AUSMHLY Distributor cap center pin melted Austin Healey 5
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
L Light for BJ8 Center Dash Panel Austin Healey 17
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
A TR-3A wooden center dash panel photo??? Triumph 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
P Turning to Top Dead Center Austin Healey 11
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
Bruce Bowker BN2 center horn button assembly Austin Healey 21
