Cap and Rotor
MY66AH
I need a good replacement cap and rotor for my '66 Sprite, 1098cc. The cheap one from Victoira wore out for the back cylinder. Thanks for the help.
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
Monark192 No Power - replaced coil, wires, rotor and cap MG 3
K TR2/3/3A Distributor Cap&Rotor:Who has the best for TR3? Triumph 6
R Source for Ferrari 328 distributor cap and rotor Other Cars 7
J Spitfire spitfire not starting, cap and rotor Triumph 4
L Gas Cap Recommendation Austin Healey 1
mctriumph TR2/3/3A Hub cap emblems Triumph 2
L T-Series Gear box servicing cap. MG 5
C MGB New plug wires and distributor cap MG 10
F Wanted Dipping switch cap Triumph Classifieds 1
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
Overdrive45 Trim Under Convertible Cap Austin Healey 11
E TR6 Strange Steering Rack Cap Triumph 3
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
P MGB Mgb gas tank cap MG 7
A TR6 TR6 Distributor cap issue Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
M TR6 Center cap for wheels Triumph 2
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
S TR2/3/3A TR3 gas filler cap Triumph 1
Ripper01 For Sale TR-6 Valve Cover/ Cap Triumph Classifieds 0
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
Jayplum TR2/3/3A Grease cap Triumph 25
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
T TR2/3/3A TR3A Gas Cap Triumph 15
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
Jim_Gruber Spare Wheel Cap for JBW Wheels Spridgets 1
Michael Oritt Gas cap parts now in tank Austin Healey 17
AUSMHLY Distributor cap center pin melted Austin Healey 5
C The ongoing saga of the "Trafalgar Bottle Cap" Austin Healey 4
K TR2/3/3A Valve cover breather cap? Triumph 5
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
F Austin Healey Sprite MK I - master cylinder cap Austin Healey 1
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
K TR2/3/3A Gas Cap Seal Replacement Hack Triumph 0
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
R Main Bearing Cap Removal Austin Healey 12
